Hey just put a new 6 boost manifold on my rb20 an did have a cheap chinesse manifold on it an the car sounded deep an tuff as but now with the new manifold it sounds a bit like a hyundai note which is pissing me off.Only other thing ive done is mount the wastegate down near the bell housing.Im goin to hav to put another muffler on it to take out the ricey sound,anyone had similar issues? thanks running a gt35r an 45mm progate if that helps..
https://www.sau.com.au/forums/topic/270043-new-6-boost-manifold/
Never mind the sound, what's the difference like on the road?
As for the sound you dont want to sound ricey, just took car for a spin then boost doesnt seem to come on earlier but it does a little more voilently,pulls real strong.It has made 402rwhp so ill put it bak on the dyno an see if there is any difference with the 6 boost.
Edited by blow thru
Have you spoken to Kyle about it?
Maybe you had an exhaust leak before so it sounded 'tough as' but now it's actually working properly it sounds 'normal'??
exactly what i was thinking
soon as i saw "chinese" manifold and a "deep note" i thought - crack/leak somewhere
Sorry dude but I just have to point out the irony here...Isn't making a modification just to acheive a cosmetic outcome, 'rice' in itself...
Hahahah
True, though i dont think thats entirely what hes doin.
I think what hes saying is that hes pissed that a expensive manifold sounds worse than the original cheaper one.
6boost manifolds that I have heard result in a more tuned pitchy note, sounds awesome. If you don't like it - give it to me :P
Mine certainly did, went from an Internally gated GT3540 on standard manifold to 50mm externally gated 6boost setup and the sound difference is amazing.
Screams rather like some of the old group A cars do.
Funny i had the same thing happen to me.
Cheap china manifold= tough RB sound.
Then put on a 6BOOST item and things quiet down a bit, i put this to the smoother runners and design of the 6BOOST manifold.
Then i put on a HKS 3.75inch exhaust, now it sounds tough again :P
http://www.youtube.com/watch?v=_PK__72sRIE...player_embedded
Definately not knocking Kyles manifold mate i tell ya well you guys no this is a work off art.I havnt had a chance to really go over the exhaust an check for any leaks but this can only be the cause,its hard to notice it at idle its only when at cruise under exceleration which leads to an exhaust leak somewhere.ill suss this out first thing in the morning.
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
