Hey,
anyone know where i may be able to get rust fixed ?
i got surface rust and rust ontop of my strut towers. want to get it looked at soon.
anyone had bad rust fixed or know of anyone that does restorations ?
need to be pointed in the right direction .... Thanks
TJ
https://www.sau.com.au/forums/topic/270060-rust-repair/
quick update, took it down to PJ Panels, Popes Rd Keysborough.
he quoted $700 if its just the top plate and suface rust on the strut tower itself. Or $1000-1200 if the strut tower is rusted through, leaving the engine in and just dropping the suspension.
:D pretty happy with that, will be getting onto that around August when money is kinda free'd up abit.
i will post after snaps and quality of work once completed.
https://www.sau.com.au/forums/topic/270060-rust-repair/#findComment-4597759
Looking at those photos, if this were my car I'd be getting to him to strip the panit off most of the area shown in those photo's because I can see paint bubbling and rust spots well away from the obvious rust areas near the shock mounts. Also the big rust areas could be associated with cracking of the shock tower probably caused by load transfer from the strut brace. Hopefully the repairer knows what he's doing.
https://www.sau.com.au/forums/topic/270060-rust-repair/#findComment-4598817
yeah he's taking the whole plate off.
and sanding the surrounding area's. if he see's bubbles he's gonna sand them back and inspect and treat.
he pointed out a few spots that i didnt see near the ABS behind the strut. he's a restors cars also so he know's his way around rust :(. i have faith
https://www.sau.com.au/forums/topic/270060-rust-repair/#findComment-4599090
if your keen on a second opinion Take it down to Micolour, 7 Dissik St Cheltenham
Already been nagging him to go see Michael. I was more than satisfied with my repair work done there, and it will be back for pre-sale touch-ups!
https://www.sau.com.au/forums/topic/270060-rust-repair/#findComment-4599593
rust is caused by moisture.
picture engine bay strut towers, unpainted i belive. then some braniac comes with an idea. lets weld a metal plate over each side for extra stiffness.
they do, and then they paint. and now what ever moisture has built up between those plates through hot and cold conditions, (not to mention the amount of salf the japs use on there roads to clear snow)
is rusting its way out. im hoping its only rusted up, but i doubt it, i got knocked back from one place saying it would be ' financially impossible' .
if it cost's more well then the trusty credit card may get used.
and Freddy, there was a little strain at the show and shine, but before hand i used Cutters (cut and polish stuff) to spiff up the engine bay, ever sinces then it has gotten worse :P
https://www.sau.com.au/forums/topic/270060-rust-repair/#findComment-4609076
Just wondering, is it caused by structural fatigue due to hard cornering etc?
but i have no rust and my car is stiffer and older, and driven harder i recon... rust is caused by oxidization, maybe bad treatment from factory, or from a snowy area, being a stag
https://www.sau.com.au/forums/topic/270060-rust-repair/#findComment-4609259
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
