  • 4 weeks later...
  • 3 months later...
Well after a long wait, and a lot of patience i finally took the plunge and attempted to fit a 34 GTR exhaust (Impul) with stock GTR cat to my GTT split dump/front pipe from JJR.
Several hours and a broken turbo stud later and its on, but...
I can now confirm that a gtr catback (at least the one i bought) does NOT bolt up to a gtt, it is infact too long! its about 3/4's the length of the cat too long, so about 8-10inches
So now as it sits, i have my JJR 3" front/dump, mated up to the mid section of the cat back, minus the cat, with about a 8-10inch piece of custom pipe to make up the difference in length, which then joins to the end pipes/muffler
Further more, when i get a new cat, the system will no doubt need a little chopping and changing to accomodate the size, assuming its longer than what is already there.
So no, a gtr catback will not bolt up to a gtt without a little customization.
Big thanks to all the guys at Al's Race fab and mechanical, worked tirelessly through the night to get me back on the road
the hangars were ok, a little tight toward the back of the end pipe,
The Impul gtr exhaust sat perfectly in the centre of the cut out section in the rear bar, nicely tucked up under the car.
The stock gtr cat would bolt up to the 3" dump/front pipe i got from JJR, but i dont know how it would go with a stock gtt cat, im not sure if the flanges would be on the same angles
RusH, you know you could have just bought a R34 GTT exhaust system... :D
Straight bolt on fit and I am sure IMPUL make one if not other Japanese brands make exhaust for the R34 GTT.
RusH, you know you could have just bought a R34 GTT exhaust system... :ermm:
i spent $550 on a full 3" turbo back system... im fine with the customized way :), jumped on a good opportunity when it presented itself and got the full system at a great price (installed for free as a bit of a trade off)
I see...
That sir, is a great deal! :)
Well as long as it worked out fine it's all good.
I see...
That sir, is a great deal! :D
:D sure is
Will be getting the mid muffler removed shortly to increase the noise and putting in a metal cat as well
:D sure is
You want more noise..?
Brisbane must be pretty lenient...
Haha!!
Haha!!
well i have to say, with the oval tip muffler and the mid muffler, the exhaust is not much louder than stock, it would be great for a stealth application, but id like a little more of that RB growl :)
Yeah true, I too just bough a Veilside Oval shape muffler (Cat back) and before it was on a R32 GTR, heavily modified and it sounded quite, so it should sound similar to my stock cat back, but just a tad louder.
BTW, GTR exhaust's have twin out lets into one - molds into the front pipe.
So what did you have to do to make it fit? Block off one of the inlets on the exhaust? Cut it off? Block it off?
Well mine is a cat back, so its only a single pipe from the cat section back, so it was just a matter of lining it up and bolting it in, a new piece of pipe was used to make up the extra 8-10inches after removing the cat.
That is all mated up to the GTT bellmouth dump/front pipe
i spent $550 on a full 3" turbo back system... im fine with the customized way :(, jumped on a good opportunity when it presented itself and got the full system at a great price (installed for free as a bit of a trade off)
So did you buy a full exhaust or just a cat back... :P
I can see a pic in your avatar, got any more?
^^Looks great RusH!
The fitting looks nice and neat too.
Good exhaust flow for sure.
Thanks dude,
Its tucked in pretty good, and has decent clearance, so it shouldnt cause problems when i get some coilovers on, and it doesnt rattle or move about either, so all in all im pretty happy :P
Wonder how well an R34 GTR exhaust would go on an R34 GT-T sedan then, if it's too long for the coupe.... There's an R34 GTR cat-back exhaust I'm eyeing off at the moment - but I don't want to go to too much effort modifying it to fit.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
