Hi Guys,
I'm in the process of re doing my R34 GT-T interior, I've narrowed it down to two seat selections, either Recaro SR3's (which will be retrimmed in black leather), or R34 GT-R seats, which I won't re trim due to the cost of the seats.
Any ideas or input as to which seats would be the better choice would be appreciated.
Thanks
https://www.sau.com.au/forums/topic/270253-seats-for-r34/
^ there's no real difference with any of the R34 GTR seats unless it's M Spec which means it's been retrimmed in leather right?
Recaro SR3 with genuine rails will fit fine...
R34 GTR seats in your GTT will require GT-T rails to suit, the GTR rails won't fit
https://www.sau.com.au/forums/topic/270253-seats-for-r34/#findComment-4600344
I would go with the R34 GTR seats. I've had them in a few of my cars now. I love them in my 32 GTR and liked them in my 34 GTR too. the SR3s are nothing that great. plus the R34 seats will never give you any grief legality wise.
https://www.sau.com.au/forums/topic/270253-seats-for-r34/#findComment-4600656
since you are retrimming them in leather i'm guessing your not into 400rwkw trackwork so i'd say go the r34 gtr seats, they loow hawt
BUT
if your gonna retrim them anyway, get the eastbear copies, should be able to pick them up cheaper.... give j-imports a call :P
if you wanna see what they look like in leather, have a look for pics of the dahtone racing r32, its owned by user dahtone
https://www.sau.com.au/forums/topic/270253-seats-for-r34/#findComment-4605492
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
