  • Replies 218
I've just got off the phone with UAS and they have had some delays with the manufacturer. At present the arms are getting the final coating done and should be ready in the next couple of weeks.
yea sorry lads as i have not been here for a while( group buy section) as i have not heard anything yet
have given john a kick in the arse.... but he is waiting on a machining shop
if you want to bail i can refund your depsit
john says it will be only a few weeks..so hold on!
if you need a chat or confidence knowing that your 200 hasnt been pissed up against the wall(which it has at the casino)
give us a yell
pete
0448468884
Will these be for sale after this groupbuy? I wanted to be apart of the GB but funds have been tight up until now.
I really want these so I hope they will be available.
Or if you can ship to Canada and someone is going to drop out I will take there spot!
group buy is sold out so they made 40 and its fully subsribed so john says
So who's on the list to get them? I have money sitting here ready to pay the full amount when ready.
im sure they will make a few extra but you may have to wait
who gets them are the people who fronted the $200 first up
if people pull out then your in
pete
Copied from aus300 website...
So I went out to Bosenjack engineering today to have a look at these things for myself and get some up to date pics for everyone.
Tell you what they put on the best smoke and mirror show I have ever seen. Awesome workshop, very clean and well equipped. Terry is a tope bloke he took a good half an hour off to show me all the bits and pieces, draw diagrams, answer all my questions, etc etc.
But I guess you all want the pictures? For starters here is a shot showing all of the pieces made up and ready for assembly. I will save black baz the trouble and point out myself that the bits are in fact silver, not black (or paisley, tartan, plaid :P) as previously indicated. This is because the zinc coating process for black is not perfect and can result in a slightly tarnished finish. An executive decision was made to get these done sooner with the better finish than to bugger around trying to get the black finish perfect.
And this is what they look like assembled
Terry's work is far better than the prototype that was supplied. For starters the end pieces are not just welded. The large section is notched and dowl pinned, and the small piece has a ball end at the T piece so that it fits together and is then welded. See illustration below.
The parts have all been heat treated and hardened, and the arms are completely serviceable.
As discussed at some length, the fixing system now uses a cotter pin instead of a grub screw. For those that were as confused as I was, the advantage with a cotter pin is that it is a tapered thread with a nut so that it positively fixes into place and cannot come loose. The picture below shows where the grup screw was used (see red circle) in the original design.
See below for an illustration of how the cotter pin is used in the new arms. Have to stress this is not a brand new design, it's an improvement on the what Terry was originally working with.
So what's the holdup? As I mentioned before the cotter pin is tapered, so you have to drill the tapered hole before you make the pin. At the moment the guys are waiting for the tooling to turn up so that they can drill and make the pins. The remaining labour is minimal, as in less than a day to finish the set. As soon as the tool turns up we are all good to assemble.
pete
No Probs, I'll keep my eye on this thread and please PM me if possible if there is a set for me. I will transfer the funds strait away.
Edited by DSTROY
I've been actively watching and posting on this thread from day one I didn't pay a deposit as I thought we where waiting for responces for construction turn around times Fatz are all orders been taken already or can we now place orders and pay a holding deposit?.
Dave
Hey guys, I have had a buyer pull out on AUS300. If anyone wants to buy his order you will need to pay $197.50 deposit.
Drop me a PM, first in first served...
DSTROY has got these, was first in with the PM by roughly two hours.
There is already a second run in the pipeline that will be much smoother as tooling etc will already be in place. There is enough material to make another 30 arms but need to get the first batch out the door first.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
