  • Replies 218
Fatz / Rob260,
When do we need to pay the final amounts? Do we pay these to UAS or through you Fatz (more cas money for ya :) )
Hi mate, not 100% sure how fatz is doing things BUT the way I run it on aus300 is money due when the parts are ready to send. The balances (plus shipping where applicable) get paid direct to UAS.
You will have to clear that up with Fatz though if you are part of his group buy.
When are the second group buy orders commencing roughly.
Won't start taking orders on these until the first batch is out the door. It's great that so many of you guys are keen but I think taking orders for a second round with the first still overdue would be asking for trouble.
So what's the holdup? As I mentioned before the cotter pin is tapered, so you have to drill the tapered hole before you make the pin. At the moment the guys are waiting for the tooling to turn up so that they can drill and make the pins. The remaining labour is minimal, as in less than a day to finish the set. As soon as the tool turns up we are all good to assemble.
So how far off are we now?
Got another set up for grabs from round 1. Guy has no job and money is tight... $197.50 to whoever gets in first.
Re timeframe there is minimal work left, just a case of when the tooling turns up.
Hi mate just after those camber arms...
so 197.50?
i read there were two versions somewhere, track and street, is this the case and if so which one is this set?
so does 197.5 cover the whole lot?
PM ASAP
Fatz: PM sent last week.. still after these, paid deposit 6+ months ago, want to know how I make final payment and receive the arms.. Talk to me bitch.
well i tell you what
johnny just called and he is picking the suckers up as i type
he has requested teh last payment and shipping and he will have them shipped within the week
the list of people who have paid a deposit are:
zurlox
lotus folding
ezzo
salad
pedator
adam macbeth
chris hall?
razor 32
john camber
my gtr32
yea baby were on!
two option
call me
0448468884
you can pay me
or the prefered option is call unique autosports 96209000 and they will tell you the shipping and give you bank details
pete
Pete, I'm going to get these sent to my work. If they're being posted I can only use a PO box. If couriered then only the physical address. Which shall I quote? Also, can you confirm the total asking price and the deposit amounts? I won't go into why I don't know, I just don't......Finally please can you confirm I'm getting a 'race' set.
Thanks.
EDIT....is it $395 / 2 + $20
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
