I'm bidding on that tomorrow. not for parts tho, for my own daily
So BACK OFF :sick:
wish me luck! does anyone know the history of the car?
Good Luck!
Besides the fact that it was stolen... I don't know any more than that
Edited by iamhe77
  • Replies 159
Will do,
can anyone tell me from the photos does it have the navi and all the bells?
Make sure you inspect it well. I've bought a few theft recovered vehicles and there could be significant stuff that you can't see. The crim could have driven it over kerbs, trashed the hell out of the motor or gearbox (they do that sort of s*#t to them). I'd be checking the underside and suspension. If you can start it that'd be good too (they will let you and sometimes help with a jump). Find the compliance plate too as you may have rego issues if it's gone.
From the looks of it it had an aftermarket stereo (face plate is not on), OEM didn't have removeable faceplate. It's got the screen but that doesn't neccesarily mean it'll work, if the DVD Rom was removed when they fitted the stereo it won't work at all.
Hopefully that wont be happening for a long while.. i've wanted a stagea for so long now!
Hope it has been worth the wait, they are a great car to drive that's for sure. I can't believe I was considering blowing masses of money on a new Holden Commodore Sportswagon.
I'm also glad I seen the Stagea before I went and brought a VZ second-hander too, I looked at a few but they no where near as good as a Stagea.
Hopefully we will catch up with you at the meet next month :(
I'm already shopping for new parts on Yahoo :blink:
will see how it goes, i need to sell the hilux before i think i can get this car registered/insured! i cant wait to take this on my trips to the snow!!
The Snow mode works a treat on the snow.
Yes, all the AWD ones do.
I used it getting into Hotham (which is at 1750m) in the middle of a blizzard after rain. so the road was icy and very slippery. But this mode made it easy as you don't get the boost coming on so quickly so it avoids all the excess torque as you keep the car going.
Cheers
Andy
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
