More the Merrier.
But we have a limit to the number we can Dyno in a day :P
Should be ok.
Sweet,,its pretty much down the road from my house so i'll come down, if anyone cancells, i'll run my car, but either way put me down for a run, i'll pay on the day. Are the runs scheduled?
Benzino33: Hi mate, If you are 100% going to run then can you please email ([email protected]) the following:
Fullname, Car Year/Make/Model and Mobile and your email
Yes, the Dyno is scheduled and I am doing the dyno timetables sometime today and emailing everyone.
Timetable (Not Set in Stone)
http://www.gtcarclub.com/19thJuly2009_DynoRunTimetable.htm
We might be able to fit a few more in if you come around 3pm.
I see Snowys coming down with his R35 GTR yeah...
That is a must see on the dyno for sure!
The R34 GTR and EVO X will be interesting too.
Guess the kW's of the R33 GTR... Is it stock? :P
Also wanna see what the Commodore twin turbo pulls.
SWeet, e mail has been sent
I cannot disclose the R33 GTR lol .. just come down and see haha
Benzino33: Come down at 2pm and we will try and fit ya in somewhere. Or you can come earlier.
Sometimes if people are running late we might be able to squeeze ya in.
But I'll put ya down on my list. thanks
All goods, I'll be there by 2..might come a bit earlier,, wanna see than Ferrari :banana:
cheers
cool turnout. I forgot that the diffusers need to be off the 34 to get it on the dyno. It was also a good excuse to not be toasted by Snowies R35GTR which pushed 349 at all four. We snuck a little roll on and the 35 was able to creep away from me.. she's a quick unit. I reckon I'd take a stocker but once the power up kit has gone in it is all over...
Hey Everyone,
What a great turnout!
I would like to thank (in no particular order):
- Greg, Mario, David and other guys from VCM Suite for doing a great job. We recommend them for your next Dyno Day!
- Sam, Pauline, Seum and Rach for organising the BBQ
- Jack for allowing us to use his awesome R33 GTR as "Guess The Kws". He made 329 kws @ all 4 wheels!!
- Danny from Martini Racing for their support.
- Snowy for bringing down his beast and making us all drool!! Since he arrived noone saw the Ferrari F430 parked next to him anymore. :)
- Tim for taking me for a spin in the R35
- Sneeze Inc., Agentz, TOCAU, MelbS15, SAU and EvolutionOz guys for coming down and showing their support.
A few unedited pics thanks to Rey.
http://www.gtcarclub.com/Resources/!ev...oDay/index.html
Thanks
Regards
Brandon
Guest
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
