Wondering if anyone is going over for this? is there another thread? what are the dates and the like??
it seems jetstar is good for trips? are they worth it? or better off flying someone who will get there..
2000 return for 2 adults seems ok.
https://www.sau.com.au/forums/topic/271643-tokyo-auto-salon-2010-not-2011/
^ PM Ash or Richard I guess.
If its 2010 I could be up for it...especially if its snowing in Hakuba, although it was mostly R35s on display at TAS last year. I'd have to budget though...cost me a wack last time and all I brought home was t-shirts and souvenirs. Have you thought about the Nismo Festival instead?
You should hit Hokkaido Mr Keets...
you can pick up tickets thru Skymark for 9000 yen Haneda to Chitose/sapporo..then bus to Niseko..
I have a place up there I could do for cheap plus beers..doesnt come with candy but!!
meh. TAS is ok. worth doing once I guess. but I'm way over it these days. it's no where near as good as it used to be. and there are heaps better car related events to do and see in japan. and thankfully plenty that aren't on in the peak of winter! (unless you want to go boarding in which case it's perfect).
so yeah, I won't be doing TAS, nothing really special on the horizon for it to make me want to go. unless they are putting the 32 GTR back in production with a rear AWD transaxle with 6 speed DSG and a 3.5 litre triple turbo RB26 that revs to 12,000rpm. are they?
What date it the nismo Festival usually on? i'm not that keen on Tas, would rather just go for the snow, and Mark your offer sounds good :)
But i neeeds the candy!!
i shall see how i go for the next few months with money
I will be possibly be attending TAS2010.
Will there be any other possible motorsport events around this time around the Tokyo vincinity?
interested in Nismo festival aswell.
Is there some sort of motorsport calendar?
Thanks
Welllllllllllll.
http://www.e-autosalon.net/tokyo/for_press/teaser/index.php
Stranger things have happened though.
Its the next illogical step so some would argue its the most logical step.
Transaxel Pre-35 GTR with 1200hp from an RB26, isn't really that hard to imagine.
lol Dr. Evil-rolled
We will have to wait a while for the dates on the Nismo Festival. Probably August before we hear anything. As for snow, if it is at the end of November we'd be lucky. A couple of weeks into December would be good.
  • 1 month later...
You definitely don't want to combine snow and Nismo Fest... That's what it was like in 2005. It really sucked cos all these special cars were just sent on parade laps, and some didn't even come out of the garage (things like the open top Grand Prix cars of the '60's). And of course, no smoke or high speeds for the drift exhibition match. :pirate: But anyway it was an incredible experience. And thanks to the chaps of R31 House who drove us there and back.
  • 4 weeks later...
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
