  • Replies 343
Posted Images
I don't think the story has gone stupid...It's kinda you good ol' bytrayal but the story is too short. even though I have died about a million times (playing on hardened). I would have like the storyline to go for at 8-10 hours.
http://www.tek-9.org/news/iwnet_alle...irus-2173.html
IW.net allegedly spreading a Trojan virus
Posted by Steven dfb Leunens on 2009-11-18 15:06:44
Tags: MW2, trojan, virus
Reported in this forum post on the official IW forums and our very own forums apparently hackers have found a way to go around the IW.net system and send a Trojan virus through the IW.net system to Modern Warfare 2 players. Reverse engeneering the source code for Modern Warfare 2, the hackers inserted their Trojan and used the IW.net system to spread it to players across the globe. This was brough to light after several players got notified of a breach in their security by their antivirus software. The Trojan TR/Crypt.XPACK.Gen had been sent to them using Modern Warfare 2's IW.net as the official transmitter (according to the antivirus). The Trojan itself apparently already surfaced in Call of Duty : World at War and is some sort of keylogging software hackers use to steal keycodes or potentially worse (stealing credit card information for instance).
The Trojan would exploit the port that is opened by Call of Duty when you are a listen server (when you are the host of a game) to send you the Trojan without your knowledge.
I lol'd, however it appears to be a false positive or at least claimed to be.
Edited by DivHunter
not as good as the first one, but pretty good none the less. was hoping it was going to be a little more mind blowing than it was, seems like it was just more of the previous version
only mission i cant do on veteren is that fkn safehouse... pisses me right off
on to assassin's creed 2 very soon
Quick answer: No.
Longer answer: No it isn't.
Reason: The game is great but for the singleplayer to only last 4hrs worth of gameplay, there is only so many times you can repeat it. Even Spec Ops requires online to complete some of the missions.
Edited by W1ngnut
I own Modern Warfare 2 on PS3, I played online for the first time last night since buying it when it first came out, DAMN there are some hard out dudes on there....
anyways if you wanna add me my USER NAME is nforsa
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
