Got my hypergear turbo installed yesterday.
I've got an R34 GTT with the following mods...
Full turbo back exhaust (only thing holding me back here is a compliance cat)
FMIC
Pod Filter
Z32 AFM
870cc siemens injectors
Hypergear TR43i turbo rated at 500HP (14psi for now)
Walbro fuel pump
Iridium plugs
Splitfire coil packs
HKS SSQ BOV
Nistune ECU
98 Octane fuel
Went to trent at Status tuning yesterday to get a Nistune board installed and get all my goodies tuned. I really have to say, Trent is one of the best mechanics I have ever dealt with and would always be comfortable in taking my car there.
Got the car on the dyno and tuned it up and ended up getting 241.5 rwkw at 14 psi. We tried going 15psi, but my clutch was slipping like crazy, so we left it at 14psi. Trent did say though that the car with the mods will be capable of achieving 280rwkw as it ws responding to the tune very well. So it looks like I will now be saving up for a clutch and going back to Status.
The car is a bit laggy, but after about 4000rpm the car goes ballistic and sinks your head in the seat.
I couldn't recommend the service at Status tuning enough. Thanks for all the work yesterday guys.
So the end result now is 241.5 rwkw. I will try and scan the chart when I get a chance and put it up.
https://www.sau.com.au/forums/topic/271936-hypergear-tr43i-turbo-tune-done/
  • Replies 55
FMIC
Pod Filter
Z32 AFM
Walbro fuel pump
Iridium plugs
HKS SSQ BOV
Nistune ECU
98 Octane fuel
Out of curiousity how many kilometres has your car done?
Sounds good, will be interesting to see how far the walbro gets you.
My one fell flat on its face at 260rwkw, then had to go 044. Good power but, probably right on par with the mods.
I thought these were good for up to 500HP. Oh well, if it shits itself i'll just go down the Bosch path.
nice result! Im looking at going to one of these turbos, as the kkr480 just aint up to the task.
These turbos are really good from what I have seen so far. As I said, just a little laggy.
FMIC
Pod Filter
Z32 AFM
Walbro fuel pump
Iridium plugs
HKS SSQ BOV
Nistune ECU
98 Octane fuel
I picked up one of these turbos about a week ago almost finished putting it in for my r33, results sound good at 14psi, out of interest if your the stock clutch?
HEY awsome to see your results, I thought i had settled on the path that i was going to go down untill this post.
I have practically the same setup except PFC and 650cc seimens injectors.
I would love to see your dyno printout overlaying the RB25 highflow with the G3 profile that URAS tuned for SS8_GOHAN.
any chance of some photo's of the install so I can compare the pro's and cons to both setups. (mods to piping)
By any chance did you get any comments made about tuning the Seimens injectors? as i haven't installed mine yet
regards
Chris
something doesnt add up
your making 241rwkw by 14psi on the standard clutch??????????????????????????
either something is wrong or you dont have a standard clutch
my stock clutch couldnt handle 185rwkw and died
i dont know of anyone who has gone over 200rwkw with stock clutch
not saying its impossible, but i am VERY surprised to hear you say stock clutch still ?????
definately the standard clutch. Car has only done 63000 so clutch wouldn't be crazy dead yet. Having said that, it's not going to last me very long from here on at all. Maybe there is a bit of a difference between the 33 clutch and the 34 clutch. Not sure about that though.
All I know at this point in time is the only way to go up from here is with a new heavy duty clutch.
i do, i just need a scanner. I will try and scan it at work tomorrow.
On the graph you can see it slips after about 5000rpm on the 15psi run but on the 14psi run there was no slipping.
how can u see it slip other than loss of power (ie the graph pointing downwards) because power is not being delivered from the engine to the wheels properly?
so how do u get a power reading of 240rwkw?
stilll though, good work on the result.
Adam
R34 clutch fairs much better than the R33 item.... remmeber the r34 and r33 have TOTALLY different clutches... also the car would slip after a few pulls which is why we stopped chasing results.
Edited by URAS
I didn't realise it would be this laggy and this is the one Stao at hypergear recommended.
congrats on the result man, hopefully a new clutch should net you a few more kW!
you say it's a bit laggy... any reason why you didn't go for the slightly smaller tr43?
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
