Ive just had a Vi-Pec ecu installed in my R34 GT-T by godzilla motorsports, Mark is a great tuner and he swears by the Vi-pec. Hes got the fastest GTR in Aus on Radials and hes taking his motech ecu out and replacing it with a Vi-pec.
If youve got any questions ide give him a call hes very easy to talk to.
  • Replies 85
My tuner Glenn "Lumpy" Campbell was the WA Autronic agent and is now the WA Vi-PEC agent. I went Autronic in my SR and he did the tune and when we've discussed each he hasn't mentioned that one is leaps and bounds better than the other.
The Vi-PEC will likely have better support now and into the future now that Ray Hall doesn't support Autronic and is behind Vi-PEC.
The Vi-PEC also sounds more fool proof and quicker/easier to setup and I like the sound of the active knock control on the V88 - but if E85 becomes widely available knock may become a thing of the past - however, the ECU will need to be able to control big injectors with the additional flow requirements of E85 - so that may be a consideration along with idle control etc.
I guess if a tuner is well versed in the ideosyncrycies of the relevant ECU then I guess its a moot point providing the chosen ECU is suitable for the task at hand.
Edited by juggernaut1
can everyone get over the link vs vipec argument its getting abit old now, read the old thread if you wanna argue about that, i would prefer to read decent detailed info on the unit like what sensors can it run etc.
can the v88 run and log 6 egt's? and a crank trigger setup is no problem with it is it?
Edited by unique1
At the end of the day any ecu is only as good as the guy that is punching in the numbers and that is fact can not be disputed. The best ecu in the hands of a shite tuner will give a poor result when compared to lets say a lower spec ecu with a really good tuner.
totally agree with dazmo & beer baron, reminds me of when i used to race bikes...1 of my mates on his out dated 600 would obliterate others on their 1000's, same analogy
vipec seems to be an aust. product & it sounds like a great ecu.
like most things these days that come out of aust: i.e. pfitzner, ppg, motec etc...better keeping the money here than o'seas IMO
Vipec is actually designed and made in NZ.
Vipec is a great ecu and is Australian like Split Enz & Russell Crowe. :down:
  • 3 weeks later...
I got a price on the vipec v44 plug in for r32 gtr from insight motorsport...$1880 ecu alone.
$3331 installed and tuned...which i thought was a bit much considering i have seen godzilla motorsport quote $2500 supplied ,installed,tuned.
Who else can supply and tune vipec in sydney...or i just take it to godzilla motorsport.
DiRT chime in if you would.
No offence but has the VIpec been tested with a new engine configuration - as in mutiple cam control, DBW control, knock sensor retard functions? This is one area where all aftermarket ECU's seem to fall over. I'm yet to see an aftermarket ECU control Cams better than the factory ECU in almost all applications let alone DBW control - f**k me, most even struggle with stepper motor control!
You would think by now that most aftermarket ecu's would be at least able to deliver consistant injector and ignition control -but I've seen issues with all the big name ECU's - including Haltech, Motec and Autronic!!
On a side note I had a look at the Vipec interface - looks rather clumbsy! Was it copied from Motec?
no offence at all...great questions.
do yourself a favor...jump on the vi-pec forum and ask Ray Hall yourself. its the best way to answer any queries by going straight to the product development team.
ezy 9's the price of the vi-pec has increased due to manufacturing costs (5%) Mark is looking after you if thats what he quoted for the instal and tune.
Edited by DiRTgarage
we do the ecu, 2.5bar map and temp sensor for $1650 its a bit over the rrp but import duy and freight from NZ is a bitch.
as for sydney JEM or anyone for that matter should have no issues with the vipec / LINK its software is very self explanatory.
Edited by URAS
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
