HKS's ultimate street modified "R."
Engine
- HKS RB28 kit (forged pistons, conrods, crank) [2,771 cc]
- HKS V-Cam system
- HKS T04Z A/R 0.81 single turbine conversion kit, GT wastegate
- HKS metal head gasket
- HKS Power Flow filter
- HKS head
- HKS stainless steel manifold
- HKS metal catalyzer
- HKS High Power Muffler EV-R
- HKS R-type intercooler
- HKS oil cooler
- HKS F-Con V-pro ECU
- Custom carbon oil catch tank
- HKS Twin Power ignition amplifier
- Custom carbon fuse box
- Custom relocated power steering tank
- Carbon radiator shrouding
Drivetrain
- HKS triple plate clutch
- Front LSD
Suspension & Chassis
- HKS Hipermax Performer adjustable suspension kit
- 9kg/mm springs (front & rear)
- HKS carbon front strut tower bar
Wheels & Brakes
- Yokohama Advan Model 5 10.5x19 (front & rear)
- Yokohama DNA GP (275/30/ZR19)
- Endless 6 pot front and 4-pot rear brake kit
Exterior
- Nismo side and rear skirts
- Rear wing stay extensions
- Nismo clear front & side repeaters
- Nissan factory oil cooler intakes
- HKS Kansai Service FRP hood
Interior
- Full Robson Leather leather/carbon leather interior
- Nismo 320 Km/h orange combination meter
- Robson Leather factory steering wheel leather kit
- HKS Turbo timer
- HKS Circuit Lap Counter
- HKS A/F Knock Amp
- HKS EVC boost controller
- HKS EV-R control unit
- Alpine CDA-9805J CD Head Unit
- Robson Leather Carbon center console
- HKS D1 shift knob
- HKS F-Con Navigator
- HKS Oil pressure gauge
- HKS Boost gauge
- HKS Oil temperature gauge
- HKS V-Cam control unit
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
