  • Replies 42
Left is Nismo NM35 kit with a Takero's bonnet extension and a very interesting Stagea grill (I want it and the Nismo kit!)
Right is Balsinari NM35 kit
I definately like the Nismo kit. The grill I've seen before and I think it's dolphin. THe Balsarinari or as I like to call it the park bench doesn't do it for me.
Do you have an ARX-4 or RS4?
Cause with the Autech Axis kit, you cant use them on an RS4 as they dont have overfenders, while an Axis front bar has the contours for the overfenders.
Bugger hadn't thought about that. Maybe it's factory aeor for me. Now if bissebee can just buy himslef a nismo kit or something I can have his :blink:.
I dont think it will fit. Looks like an Axis grille
Does look like an Axis grill, but wouldn't it fit?
I don't think that the Axis front bar has a deeper section for the grill and all M35's have the same OE bonnet.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
