jus spent the last hour on search trying to figure this out and this wat i make of it....pleases correct me if im wrong....
there are 4 cradle bushes which need cradle to b dropped and bushes pressed in/out. alot of work and labour.
u can buy solid alloy bush cradle inserts x 8 which stiffen rear up but sum say gets noisy sum say not. cradle stays on
then theres pineapples x4 which depending on how its mounted promotes traction/grip or drift. cradle stays on.
how do u know which option to go for and wat u need. im after grip, reduce tramping and general upgrade of worn bushes. i found a nice basic diagram showing where pineapples go for different results.
sorry for being 'slow' but jus after a simple breakdown of the whole thing.
then also u can get rear diff bushes x4.
thanx
https://www.sau.com.au/forums/topic/272740-info-on-rear-cradle-bushes-r32-gtst/
get the alloy ones i did im im very happy for it
the noise factor is so small ill bet 5 that you probably will never notice it mate
but you will notice the car is heaps better to drive
did u replace the inner bushes, or just the subframe-chassis bushes? the real NVM comes from when u solid mount the inner bushes as well, which a lot of people dont.
for a daily i would stick with Urethane, especially if ur running a lot of rubber around the place and softish suspension. there are usually other causes to the axle tramp before ur subframe bushes.
What do you mean by "worn"? The rear subframe bushes are silicone filled, they need replacing when they burst and the silicone starts dripping out. If there is no silicone leak then they don't need replacing. In which case pineapples are the go as you can change the rear subframe angle, something R32's really need.
Cheers
Gary
i solid mounted the lot and im very happy
including solid uretane for the diff which means you ca hear the diff but its unrelated
come and have a drive of mine if your local and see for your self
isnt the diff solid anyway? lol
may be different on GTR's, i know R32 GTS-t's are solid, R33 GTS-t's have a bush on the front mount.
i dont care a great deal about NVM so its not something i look a lot into lol
when i got the car it was pretty much bone stock as well, but it had been converted to a manual, and a fairly budget job as well, maybe they came out when they did the conversion :S
i run some urethane bushes i made up with my R33 diff at the front mounts as it needs to be spaced down, but nothing for the 32 diff.
so the cradle bushes only need changing if they leak... ok ... mine arnt leaking so that answers that question
next is the difference between the cradle inserts and pineapples. which one applies when ?? thanx for all the replies....
u have bushes IN the subframe, where the bolts go through which holds the subframe to the chassis, then u have bushes that sit between the subframe and the chassis. the ones that sit in between the subframe and chassis "align" ur subframe, so u can change the tilt, which changes the amount of squat u get.
The cradle bushes near the doors are silicone filled, if they're stuffed its fairly obvious, the rear ones are solid rubber. When I replace my cradle bushes the front were stuffed but the rears were still ok, no tears in the rubber and looked good. It is harder to tell if the rears are gone. I replaced all four and even though only the fronts were stuffed it was noticeable under hard acceleration out of corners that there was a positive difference. Didn't notice it at all when driving normally though. If the cars a long term proposition then I would do the cradle bushes if not then you would probably get away with the pineapples.
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
