10 or 11. but one is mine.. and another is sold to one of their customers.
they will tell me a price today i gather :D
They ended up being stainless also
I'm up for one if there is one left. :happy:
  • Replies 182
No worries :blink: the dump will still bolt up to anyones jap brand front pipes. they cant get 3.25inch flanges and its a bit late to have them made..
anyway here's some progress photos from anyone interested..
you can see what i mean now by the pipes cut and done. its a very nice job and should flow very good!
they will be nicely polished up when done.
wow! and here i was thinking they would beat it into shape. very nice work!
i thought they were going to do that also.. untill i went there on monday haha.
i think 3.5inch was still going to be too small to beat into shape.
Very nice Andrew. Looking very promising indeed.
So are these going to bolt up to the standard front pipe or are they going to include a front pipe/cat and bolt up to the cat-back exhaust?
How about bolting up to an 80mm front pipe?
Can't see them flowing much more than the OE dump though...
Just kidding :blink:
haha i didnt scroll down far enough and was thinking.. this guy is on crack!! haha
should bolt up to your jap front pipe fine.. otherwise can prob make something else if need be.. front pipe is easy to do..
this will just be standard style so either front pipe is required if you have a jap cat back..
or a complete dump back exhaust is needed.. which i expect most people to be doing since cat backs from japan are stupid priced for the m35..
on another note.. where are the cats placed in this car when a jap cat back is used?? since the stock dump houses the cat..
There is a standard cat in the front pipe from what I can gather.... although my exhaust contained six of the buggers (including the dump), so maybe I am not the best knowledge source for this one.
i think that one in the front pipe is actually the compliance one..
mine appears to have two. the dump one (if its still there) and the one that appears to have been added here..
i just got a call from my friend whos making them... apparently i am installing mine.. haha hes doing one now on someones white m35
so looks like we might hear a report of how it sounds and goes today..
anyone on here getting it done?
Yo these are almost done. i will have about 8 or close to that so get in quick!
just the o2 bung and we're good to go. will get pricing soon the boss man wasnt in..
heres a photo of a couple
Definitely keen, they look great! Good work on getting these fabricated.
$450 this is including delivery and also $450 not including delivery
They will be polished up before they get sent out.
pm me about it and i will organize it all. with my details.
i have 8 ready to go!
Cheers
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
