10 or 11. but one is mine.. and another is sold to one of their customers.
they will tell me a price today i gather :D
They ended up being stainless also
I'm up for one if there is one left. :happy:
  • Replies 182
No worries :blink: the dump will still bolt up to anyones jap brand front pipes. they cant get 3.25inch flanges and its a bit late to have them made..
anyway here's some progress photos from anyone interested..
you can see what i mean now by the pipes cut and done. its a very nice job and should flow very good!
they will be nicely polished up when done.
wow! and here i was thinking they would beat it into shape. very nice work!
i thought they were going to do that also.. untill i went there on monday haha.
i think 3.5inch was still going to be too small to beat into shape.
Very nice Andrew. Looking very promising indeed.
So are these going to bolt up to the standard front pipe or are they going to include a front pipe/cat and bolt up to the cat-back exhaust?
How about bolting up to an 80mm front pipe?
Can't see them flowing much more than the OE dump though...
Just kidding :blink:
haha i didnt scroll down far enough and was thinking.. this guy is on crack!! haha
should bolt up to your jap front pipe fine.. otherwise can prob make something else if need be.. front pipe is easy to do..
this will just be standard style so either front pipe is required if you have a jap cat back..
or a complete dump back exhaust is needed.. which i expect most people to be doing since cat backs from japan are stupid priced for the m35..
on another note.. where are the cats placed in this car when a jap cat back is used?? since the stock dump houses the cat..
There is a standard cat in the front pipe from what I can gather.... although my exhaust contained six of the buggers (including the dump), so maybe I am not the best knowledge source for this one.
i think that one in the front pipe is actually the compliance one..
mine appears to have two. the dump one (if its still there) and the one that appears to have been added here..
i just got a call from my friend whos making them... apparently i am installing mine.. haha hes doing one now on someones white m35
so looks like we might hear a report of how it sounds and goes today..
anyone on here getting it done?
Yo these are almost done. i will have about 8 or close to that so get in quick!
just the o2 bung and we're good to go. will get pricing soon the boss man wasnt in..
heres a photo of a couple
Definitely keen, they look great! Good work on getting these fabricated.
$450 this is including delivery and also $450 not including delivery
They will be polished up before they get sent out.
pm me about it and i will organize it all. with my details.
i have 8 ready to go!
Cheers
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
