We the time has come for the old girl to take a rest! We looked at what was required to make the old girl competitive and it was just going to cost too much and wasnt sure she would last the distance against some very very quick race cars that are coming to race in the new GT class.
That being the case we have purchased a GT3 viper to run in the new seasons races, and the old girl will now be my track car i guess.
And i feel really gutted about it, but what else to do.
https://www.sau.com.au/forums/topic/273064-time-to-retire-the-old-girl/
LOL not the reaction i was hoping for!
I am really gutted over this but the head over ruled the heart i guess. We could not see a way within our budget to get the car to the level required.
And to be honest the viper wasnt all that expensive as we brought a roller with a dog box and have a Gen three 8.3 litre ( i do get a wee smirk on my face each time i say that ) on the way from the states. Car is to have its carbon fibre body put back in place this week so pics are a bit non completed.
As long as you can keep you GT-R and use it when you want, then I say onto bigger and better things!
Look at the bright side, you can still drive the GT-R at the track, but you get to punish 8.3 litres of American Muscle around a quick track. Sounds like heaven to me :)
traitor!!!! kindly return my RAs and pepper mill now!
ok, well now that i've calmed down a bit I reckon I can forgive you AND let you keep the RA's as long as I get a steer of the viper to ummm see how, *cough, bad it is... :D
wow 8.3L and looks pretty darn light... going to be a handful but lots of fun I imagine
that rear wing is awful... but I suppose your going to need all the rear end grip you can get... make sure to stockpile lots of tyres!
don't you also have an old porsche as well? 911, GTR and Viper... okay I'm massively jealous now
I am truely gutted about putting the GTR on the back burner!
BB still waiting for the pepper grinder to show up, thinking i might have to start a smeer campain.
Tell you what if any one wnats to come on over i might be convinced to let you run the GTR in the GTC class LOL dont know if it would currently carry enough fuel to do 45 minutes, but then the boost would be turned down for the power to weight ratio so it just might.
Ohh NICKR33 yer your almost correct i do have a turbo 964, R32 GTR, GTS-R viper, lotus exige are you sure you would want the running costs of that lot! I am not sure i do so!
lol, do not temp me (or troy for that matter) we may just take you up on it!
the only matter is can your seat accommodate me. when I'm booking flights I have to ask at check in: "hey mister... on the plane I'm going to need 2 seats..... for the twins... :P "
I guess at least if I break yours we can build you another one out of all my bits... then we can store it for you in aus and you can come and break it at phillip island, or eastern creek or something. in fact next time you're in sydney give me a shout and come drive something here. I always have something half worthy. not quite GT viper worthy, but fun all the same.
aaaagh an Exige too!... damn... I can't even manage to get one car on the track and keep it there... I would love the running costs of that lot, only I couldn't afford it without selling my body parts on the black market... or getting my wife to become a stripper... and I've already asked... she said no :P
ps. If you have too many cars and need me to break one for you I'm always available... its my special talent
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
