  • Replies 81
Originally posted by INASNT
ash 400rwhp is 300rwkw.
What turbo are u replacing your t04e with?
mmm... it's as i thought then
Admittadly im not running a rising rate reg, but i surely wont be getting another 100rwkw out of just raising the pressure.
Can you get an extra 100+kw just by fitting a rising rate reg?
i would think that's quite optimistic.
And my replacement... looks something like a GT35/40 or something.
No. Sounds like your turbo is too small to get another 100rwkw anyway. It seems by the terminal and quoted power to be something around the size of a stock RB25 turbo.
I would obviously be adding more boost and what not.
Not just putting a reg on and expecting power.
And my turbo is most certainly not similar to that of a stock RB25 turbo, the 'quoted' power if you will... is on a quite low reading dyno.
Most R33's with 12psi (stock turbo) on the dyno in question would make 160-170rwkw... just to give you proportions.
Well, going off your terminal speed you aren't making anymore power than my R33 with a stock turbo on 10psi, given your car isn't any lighter than mine. That puts you around the 200rwkw mark on a properly calibrated dyno dynamics dyno in shootout mode.
Perhaps you are running too little boost to be within the turbo's efficency range?
*yawn* I am getting tired of repeating myself. I'm making 340hp (another car is making 350hp with a different turbo) and both of us are sitting on 70% injector cycle. I dont have a fuel reg just a bosch 910 fuel pump. neither of our cars seem like they are running out of fuel nor do the injectors report as being maxxed out, they are definately stock injectors as we had them out 2-3 weeks ago to be cleaned before we put the wolf3d v4 in.
That is more than likely...
we gave it a quick squirt on 15psi one day... and there was an instant 30kw gain up from 13psi.
But then they MAXED them out totally. (i do already have the bigger fuel pump)
Not worth me going a rising rate reg, so im getting bigger injectors anyhow.
But if rob77's are at 70%... and he has what 250rwkw.
it makes me wonder. Hrrmm...
Wat size are stock 33 injectors again?
and all these cars are all coming from perth!!
is there a bermuda triangle around there?
Is it possible the methods of measuring duty cycles are perhaps accounting for variations....
So schools in, how exactly are you measuring duty cycle when you say
I imagine the ECU is measuring the signal/injector pulse width and comparing that to the full range 100%.
Is it possible that somewhere in the Wolf ECU there is a calibration issue? (Pls dont sledge me...im asking a question, not questioning the quality of the Wolf)
Has anyone using a Power Fc, re-written ECU (mines etc), Autronic, Haltec, Microtech been able to see a similar duty cycle when tuning an R33 with stock injectors at approx 250rwkws.
Roy, I think if we were actually past the 100% duty cycle then the AFR's might start to show it:D I'm very confident it's accurate, it may have more to do with the injector drivers being particularly strong in comparison to other ECU's.
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
