Hi people. Well the slide hi-flow is now out and it is now time for the 3076 to go in. In regards to the studs in the standard manifold is the best thing to get them out with is some CRC and vice grips? Also should i change the standard manifold or will this be adequate. Finally the water line that goes from the turbo to the rear of the engine, how do you get this sucker off? Any help would be appreciated. Thank's :thumbsup:
https://www.sau.com.au/forums/topic/273729-pre-turbo-install/
Studs - you are more than likely to break a couple mate. CRC them a few times during the day and leave overnight to give you the best chance at getting them all out
Stock manifold is fine
And water line - with a bit of elbow grease, again perhaps CRC overnight.
The fun continues as i have now removed the manifold because i noticed four were broken. Is it fairly easy to take the broken one's out with the right tool's or should i call in someone. In regards to spacer plate and oil lines the turbo will be coming in full bolt on kit form (spacer plate, oil and water lines nuts, studs, gaskets etc).
IMO get rid of the waterlines, i dont see a point for them, when there's hot water running through them all the time.
As for where it ends up is behind the intake manifold, undo the 2 bolts on the head, if the hose doesnt come off you can always chop a bit hoes off, rust normally cramps it and its hard to remove.
What do you mean you dont see a point for the waterlines...? The turbo is water cooled!!!
As for the broken studs - call someone in. Its not that expensive and there are mobile guys in each state :)
Try get your others out first though, likely more will crack.
Thank's for all your imput guys. As far as the bolt for the water line behind the block do i have to really take the driver side rocket cover off. I have to admit though i've tried about five times now and cannot even get the spanner onto it.
Also make sure your oil lines are correct because using stock oil line is a no no. When i had my hypergear installed bymyself... i didnt get told to install a aftermarket oil line so therefore it blew up. So make sure u get an oil line.
That cleared my miss thoughts, ive been running an rb25 turbo without them for a while, guess it couldnt be good for the ceramic wheel.. :(
Id be more worried about the core.
A ball bearing turbo by nature requires less oil to lube the bearings. The offset to this less oil means there is less cooling going on.
Hence ball bearing turbos are ALL water cooled.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
