i think its been determined that they cant be complied as yet!
however i think someone is working on it.........
True, But I very very much like the seats. . would look great in my car. . . .as would that 6 Speed manual. .
https://www.sau.com.au/forums/topic/274122-m35-manual/#findComment-4648102
WTF.................. :mad:
Why does this stuff keep getting listed? Just to stuff up the innocent.
I agree, it's extremely deceptive and I'm sure it will catch more people up if they don't do the research before initiating the purchase process.
Do these places want to be taken to court or what?
https://www.sau.com.au/forums/topic/274122-m35-manual/#findComment-4648711
Give it 3 months or so and it should cover all models, not just RWD RX (which is the car going through compliance), but all AWD models as well as the 350s.
Will be sticking with my 250t though.
Nobody told me (since I wasn't there), was the 350RX brought to the meet on the weekend?
https://www.sau.com.au/forums/topic/274122-m35-manual/#findComment-4649221
Does this mean that there is light at the end of the tunnel for Muz and the other guys with 04MY turbos? Or are they still buggered?
Still buggered unfortunately.
easy rule is
VQ25DET is ok up until Oct 2003
VQ35DE will be fine from 2004 - end of production.
https://www.sau.com.au/forums/topic/274122-m35-manual/#findComment-4649416
I've had a 350Z with the VQ35DE motor in it. What can I say, it's a lovely engine. The thing that I'm most impressed with is the sheer torque you get as soon as you floor it and it's that initial feeling that had put a smile on my face. Sure we all know that it takes a bit more time to get a VQ25DET to sing, and when she sings, she does it loud and proud. But really, it's that precious second or two that can make the difference.
What I'm not impressed with the DE engine is how it responds to your basic mods. Pretty much you need to fork out a small fortune to really make it into a real thoroughbred. I did so much to the 350 it wasnt funny, and in the end, I gave up and decided that a forced induction car was the way to go.
With the Stag, a simple dump/front pipe change with a high flow cat has already made a big difference. I cant wait till my cat-back arrives and see how much better she goes.
https://www.sau.com.au/forums/topic/274122-m35-manual/#findComment-4649918
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
