Hey guys
Just looked at the gtr spoilers carmate have on their site
not too sure how the quality on these are like, has anyone bought them before?
pics are below
apparently their all different heights.. not too sure on the quality and final look but they are a good price
https://www.sau.com.au/forums/topic/274497-carmate-r34-gt-r-style-spoilers/
carmate stuff i had a front bar didnt line up under drivers headlight, rear bar didnt fit correctly on the rear with gaps...lot of work but as said above with spoiler on two spots really need to line up for fitment so not much chance of problems compared to bars and skirts...pricing they are good quality just luck of the draw
my old r34 had a carmate spoiler on it, get the low mount one, it does get in the way of rear vision but it's not too bad
I've seen the high mount one on a GT-t and it was ridiculously high, funny looking
it did the job and the bolt holes lined up so I'm happy, that's as far as i'd go to putting fibreglass on my car personally, not a fan of fibreglass bodykits
Edited by Yo-Yo
Does the CarMate version have an adjustable rear fin?
I agree with getting the low-mount one only.
Since CarMate sell F/G, run your hand over it to check that there are no ripples. If it's smoooooooth, and once it's painted, no-one will know the difference if it's F/G or Plastic. Rear fin could have a C/F look to it (or bronze).
alright cheers guys, thanks for the pics
it looks like it'd turn out pretty good once fitted and sprayed, was worried about how the final product looked, but that looks fine
im currently using the stock gt wing, and even that gets in the way of the rear view mirror a bit, but not really a problem for me, but i'd definitely get the low one, it looks like a good height from the pictures too.
yeah i was wondering about that too, the carbon fibre look is great, looks like its meant to be
you can buy carbon fibre wrapping paper, but i doubt that was how it was done, it looks wayy too good for that
How sturdy is this thing ? Not sure it'd be so great if instead of creating downforce it ripped off and flew away into someone's windshield at high speed...
haha yeah i guess that is another thing to consider, it really cant be that bad though can it?
carmate is a pretty big site too, im sure they wouldnt sell stuff that is likely to fly off while driving .. or would they :|
R34P3R the pictures up on the first post of the pics go from low to highest. unfortunately they only show the high spoiler actually installed on the car. I prefer a low-medium spoiler personally, not really into ones that go too high.
to answer a few extra questions posed...
rear fin came c/f not real carbon but fibreglass with c/f top, kind of like how some c/f bonnets come.
wing was not adjustable, but at least it looked like it could lol
wing is sturdy, I live in western sydney so pot holes are a way of life, and I'm a lead foot too, it held up very well
that being said I am very iffy of carmates quality, as I said before that's as far as i'd go to putting fibreglass on my car
the wing was sturdy though so I was happy with it, you could place a bit of force with your hand in the middle of the wing and it wouldn't bend
I had it painted from a friend and fitted the wing myself, make sure you have some silicon or double sided tape to place around the bolt holes on the boot so no water leaks in
the only one that looks good is the low mount imo
Edited by Yo-Yo
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
