As much as I hate penalty systems for hitting other cars (time added, car slowdown etc), I would have thought that's the most effective way of discouraging collisions.
A damage system doesn't necessarily penalise the person at fault (eg tapping someones rear quarter panel while your both travelling at 300km/h ;) ).
On online if you or someone tries to hit someone else at a greater speed, the car about it hit will turn into a ghost and go through the other person so there is no collision. So say your entering a corner from the main straight and you brake late and the other guy is close to you ahead, you will turn into a ghost and go through.
was speaking to my mate at harvey norman yesterday. asked him about the release date. he said that all they have been told is that it will be november. no official date in november yet though. also no word on any of the collectors editions, etc. he said they don't normally get announced until 1 month before release.
ed games said 1st november
standard edition is 99
collectors is unknown but it comes with an R35 GTR model and a book about cars
i don't think it will be 1st of nov. i think it will be later in the month. the US has nov 2 as their date, france (and therefore most of europe you would assume) has nov 24 as the reported date. i would expect us to be similar to europe.
and i am well aware of what is in the collectors edition as i was the first person in this thread to list up what it comes with. you also left out that that it has a keyring and some bonus cars in the game. and as i also said earlier in the thread, it has been reported that there will be an ultimate edition that could be up around $400
of course there will be tyre marks on the road you jagaloons!
just be patient!
don't EXPECT anything... when you "expect" it makes an EX out of PEC and T
in the rally stages at night, the dust which is kicked up behind the car - reflects the light.
if they do THAT detail... there will be skid marks.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
