Is the G25 no longer made? I picked one of these up for $250 from Hardly Normal 3 years ago. It's connected to my Microsim Race Base (showing my age here).
The shifter quality is still pretty plastic, but better than playing on a keyboard.
G25 isnt sold anymore, the second hand ones ive seen on Ebay have ended up sellin g for the same money as a G27....
380 on ebay seems the cheapest, but also has the biggest postage $80 from what i recall. it seem the cheaper the product. the more the postage is.
i bought my G27 from Umart in brissy. cost me $405. picked it up the next day. no waiting, and no overpriced postage.
some of those driving rigs are pretty nice. but far too expensive for a few bits of thin metal tubing. and a friend has the VR one......very flimsey, not good for 650 bucks. and 2000 forget about it. mine cost me $250 for the bucket seat about 8 yrs ago ;) all the rest was free!! (except the G27 obviously)
there are other driving games other than GT5 you can use your steering wheel with. no need for it to collect dust :D
The Racebase plans and hardware cost me something like$80 back in 2004, and probably $50 worth of MDF.
I see they're back in business, and you can get the plans for $9, and hardware for $50-ish. If you're handy with woodworking, they are pi$$ easy to make.
http://www.thewayiplay.com/mainforum/index.php?topic=894.0
too much of a pain to get in and out of though. if i was going to do it i''d leave 1 side off so you can slip into it easier, or make it have a scissor door, lol
What? Seriously?
Are you an arthritic 80 year old or something? Have you actually tried these things?
I can think of plenty of reasons one might not want one of these, but ease of access? Come on - surely you can do better.
Besides, the steering wheel tilts up out of the way if you want it to (although I've never had to do that)
Each to their own though.
you are pretty much sitting on the floor. i'd rather have it at seat height. i don't have the money or space for a sim anyway, so i'll just be sticking with the controller. never bothered me in the past. i might get one eventually (when i'm in a house with more space), but that won't be for a while yet.
i'd really like to get a car and mount one in the car so the steering wheel, etc is all in the exact location it would be in real life.
looks good, and cheap, and real easy to make. would save alot of stuffing around with measurements like i did. ill stick with my alloy one tho. Sure its pretty well on the ground, and doesnt look as artsy. but its sturdy enough to use it to drag yourself out if need be. Easier to get out of than a bean bag :dry:
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
