ok just realised like the wind indianapolis is 70k prize money for around 3:30 in a car capable of winning it. go toyota gt-one :thumbsup:
not to mention the massive stack of xp you get for it as well. my 1040hp Toyota 88C-V just rapes that- can just overtake last place at the end of lap 5
will be good once my B-spec guy is experienced enough for it
still only lvl 18 :( no b spec yet.....freaking old lambo is doing my head in......as is the computer drivers....yes i am next to you....no plz dont just drive me off the road as tho im not there......i dont get it, Prologue had epic AI drivers.....what happened?
yeah i have been spun a few times by AI drivers raming the side of my car on straights after getting in my slipstream.
now come on, power upgrades on a le mans car against other le mans cars, thats just cheating. basically any b-spec driver should be able to win it no problem, in fact thats the race i've been using to level up my low level drivers. and they win with no power upgrades, completely stock, just full downforce and maybe play with the gear ratios if you have to. make sure you keep the drivers stress level up at maximum or he'll get owned. i found the low level drivers were pulling way faster lap times on that race because they just hurl themselves into the corners full tit which is fine on this one because the car is capable of it, where as the higher level ones slow down, which isn't necessary at all.
1. create new driver.
2. win indianapolis like the wind, go from level 0 to level 7 in one hit.
4. ???
5. profit
your new Bspec botman wouldn't have the required xp for that race
pardon me sir, i beg to differ.
any b spec driver can enter any race, as long as the user's total b-spec skill is at or above the level needed for the race.
have done it many time
i played the game for about 5hours and gota over it, returned it back to eb games
i was dissapointed with it, thought GT5 was meant to be Gran turismo HD,
to be honest i have more fun with the r32 gtr in GT HD demo, on that same track then i do in GT5
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
