Thanks Chris will do, gotta ring CRD this arvo and book in the tune for hopefully early next week. I thought I'd let you get settled into the unit first plus I might be giving you a buzz soon about the rims
Where did you get the catch can/washer bottle from??
Looks similar to the Just Jap item.
Its a Just Jap/Performance Metalcraft Hybrid. I got Leon from PMC to cut the 20mm barbs off and weld on the three 16mm items but the third is actually a dummy to keep the "legal" look as it actually vents to atmo but is very well hidden.
And for all those people that say the GTR Catch can wont fit into the GTST thats not correct. All that is needed is a GTR washer bottle bracket and to drill 2 small holes and it goes straight in
hey i really like your air box! it that completely custom on your part?
i wish i had something like that on mine but my intake filter is about times the size of your :S
Yeh full custom box I made up a couple of years ago, its loosley based on one that was doing the rounds on here a while back but I think mine has a better seal.
I might still have the template lying around in my shed somewhere, if I find it ill contact you via PM if you want it?
looks awesome Dave. Good to see that all your hard work and patience has paid off. well done.
Thanks Paul, Most of the parts you cant see are from you mate :rofl:
Hey Mate,
Love the detail am just wondering wher you got the airbox from??
Its a custom box I made myself a few years ago. I was never happy with the ones going around (Either didnt seal well or just plain ugly)
It was a bit of trail and error to get it to fit but i tink i have a template around somewhere for it. The only thing is its made specifically to fit the Apexi Super suction kit and "may" not fit other pod setups
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
