im am very close to completing my rb26 powered s15, its fairly full house and plan on running 9's
ive just got few questions on what you more experienced guys can tell me......
i have a motec m8 pro, which is a mad ecu, but im unsure what to run...
it only has 4 direct fire ignition outputs and can obviously run wasted spark....
my tuner tell me i must go cdi with mecury coils... another dude told me i can set up splitfires to run with a motec cdi system???
what do yous rekon??
https://www.sau.com.au/forums/topic/275163-ignition-system-rb26-650wheel-hp/
If your tuner tells you to go a specific route, and you trusted him so far with your build, would you turn around to him and tell him to set the Spitfires up because another dude told you to go that way?
How would he take that?
If he's proficient in tuning M8's, I would take his advice as he works with them and would be talking from experience.
I'm not being a dick here, just the devil's advocate so to speak. :P
ive seen other setups make significant power without going as extreme as a cdi system, my tuner is like a high maintenance woman, he likes everything expensive...
im trying to save cash but not cut corners 2 much....
a cdi system is worth 2g inc coils,
why would i throw 2 grand if i could do the same job or at least similar and get the same result for something that costs 500 bux??
Edited by den001
cdi meaning 'capacitive discharge ignition' yes?
where by a unit that contains a bank of, probably electrolytic, capactitors supply the charge to each coil pack??
or does this unit feed a charge directly to the spark plug?
have a rough idea of how this work but not entirely sure.
in theory this system makes perfect sense for great spark power, as any one who has seen a large capacitor instantaneously discharged can verify.
^ what Ash said
heaps of full-on drag GT-R's in Japan just use the standard direct-fire coil setup with the addition of an HKS Twin-Power module
i was leaning towards that as i would also save cash on wiring....
can the plug gaps be opened up with this setup?
why cut corners on ignition when uve obviously spent an absolute motsa on an ecu and probably everything else in the car.
personally id go m&w cdi, m&w coils & magnacore leads. last time i spoke to m&w total in parts was $2350, that included an installation kit, pro 16 cdi (youd prolly have to use a different cdi seeing u cant use direct fire) 6 coils, and 6 custom made leads (leads made by magnacore which m&w recommend)
also, why did u chose an ecu that doesnt use direct fire ignition? :P
Spot on Shane...
Sell the shit and buy the real stuff.
fully wired two of these complete set-ups in drag cars while in QLD.
1 x Vi-PEC V88 ecu
2 x M&W drag 6 igniters
6 x M&W coils
one car runs 18 1600cc injectors drinking methanol and ran a 6.71 @ 209 MPH....no hint of a missfire from fireup to shutdown. The car in question had massive missfire issues before i did this instal. Idles like a baby and screams at full noise like a banshee.
Can do a deal on this stuff if you get me to do the instal...a lot of the guys at the Winternationals commented on the quality of the wiring job.
The above set-up is a bit OTT for 650hp....my engine makes around 1000hp and i use splitfires and the hks box with std igniter. I use a Vi-PEC V88 direct fire ecu though...bit better than the MoTeC.
Edited by DiRTgarage
the motec is direct fire..... you should know that, i said it only had 4 outputs,
i was going to use m&w ,m&w now do a 6 channel cdi system which only uses one ignition output to direct fire all 6 cdi channels, only for motec ecu's though
costs 2grand including coils
no need for ignition expander....
i want something sufficient enough to do the job properly and "reliably" i have acquired the computer for nothing so may aswell use it...
i asked the question because ive seen and heard of many many high powered cars running more basic systems rather than a full blown cdi system....
Edited by den001
u knew what i meant though :P
well theres ur answer! get the m&w setup and never look back :P
To get around the waste spark issue you could purchase a motec ignition expander found a price on CAPA website for $340.... I run standard ignitor and splitfire at around that horsepower without problems. If you have spark issue down the track do what dirt does drop in a twin power....
im a tight ass....
whats a set of splitfires worth and that hks box???
cdi is 2 grand complete
will there be much of a price difference
sweet as,
ive been doin some reading and there are some negatives in running a cdi system, ive also been reading about the hks box and it seems to have the best of both worlds.
runs in inductive and cdi modes automically........ hmmm hard choice....
Edited by den001
sweet as,
Ive had a 2 M800's come in lately running stock coils with various amplifiers making high 500rwkw's and one making 522rwkw with the motec cdi and they all tuned up the same (no spark issues), i did not wire the ecu's so am not 100% sure on the specifics without looking into it, but i cant see you running into any issues especially if your tuner knows his motec gear.
i must admit it was nicer tuning the CDi's as they would ignite stupidly rich mixtures during setup etc and saved me time not having to change plugs :) Just for the excercise i did bit of a test and the Motec CDI could ignite mixtures all the way down to the limit of my wideband on 1.1mm gap using fine point race plugs.
Edited by URAS
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
