Hey guys,
I have some quick questions, my car is stock standard only has Catback exhaust and after market apexi airfilter pods. Everytime i get in the car ,it smells like fuel... is that normal for r32 gtr? or is there something wrong with it?
Secondly, Full tank of petrol can only go for 320kms, Is that normal? Maybe i need to retune it or something? because of the airfilter?
Thirdly, I just bought Xd9 18"rims last week. it was very close to the guard so i needed to get it rolled. Got the guards rolled 2 days ago, the paint cracked on one side as warned by the roller. He said that the left rear guard had been fixed or soemthing before and it has completely no metal at all. Anyway i want to know whats the best way to fix this?
Please help me out guys
Cheers
long
https://www.sau.com.au/forums/topic/275194-1993-32gtr/
Mine smells of fuel sometimes, they just do for some reason. Have a look for any fuel leaks.
Welcome to the world of high performance (read: high fuel consumption) cars. I get 400 to 450 out of a tank if I drive it economically. Are you still running standard boost?(about 7psi/0.5bar i think)
It's pretty common for the rear wheel arches to rust out due to the salt on Japanese roads and sounds like your was just patched with bog. Mine were cut out and new metal welded in. You'll have to take it to a panel beater to get it fixed properly.
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4662820
Im running my car with standard boost 7psi and theres still only 350kms for a full tank, so im assuming its might be out of tune?
Yea, the guard roller said if i fix it they just gonna put more bog on??
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4662882
You smell fuel, probably because you don't have a catalytic convertor, or yours have been hollowed out.
350kms is a bit low, but not stupidly so... Car might be running rich. Standard ECU?
Take the car to a panel beater... They'll have to bog up the guard again, and repaint it... Of if you want to do it properly, pay them to weld in some more metal, hammer it back into shape and then repaint.
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4663043
Hey guys,
Cheers
long
I havent come across any skyline, turbo or not that doesnt smell like fuel while idleing.....
Another thing that might cause the high fuel consumption is if the O2 sensor(s) are not working, so the car runs rich all the time.
+1, i recon its more likely than not your 02 sensors, everyone forgets to change them but nissan recomends changing them every 40 000km or so.... mines not a gtr but when i first got the car i was getting 250ishkm/tank.... change the ot sensor, new spark plugs, throtle body clean, afm clean and now up to 500km/tank while running 10psi boost and about 200rwkw, if i drive it harder i still get 400km/tank at worst....
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4663181
Hey guys,
ive owned a couple and only 1 ever smelt of raw fuel , it actually turned out to be the injectors that were leaking :D
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4663364
So you're talking inside the car right? Check the seal on the fuel tank. In the boot there's a metal plate held on by four screws to the right of the wheel well. Under it there's a big black ring that holds the fuel pump and gauge assembly. There's a seal that sits between the assembly and the ring. Make sure that seal is in good condition and the ring is tight.
Other than that i've used gaffa tape around the metal plate to stop any fumes from entering the boot. The boot doesnt have an airtight barrier into the cabin, so any smell in the boot gets straight into the cabin.
FWIW i dont think my car smells bad outside. Cat and o2 sensors are known good.
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4663826
So the stock gtr doesnt have catalytic convertor? I am running standard ECU nothing has changed.
Yes i want to get it done properly no point of having more bog :D. So much money spending on the car but i mean my car is in good condition interior is perfect, engine bay is very clean, just stupid rust underneath the rear.
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4663897
do you think i could get it check up at the mechanics? or do i need to find a skyline specialist to fix this problem?
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4663911
this is what i would be checking.
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4663952
you would want to check that the fuel tank doesn't have any perished breather hoses and also that the fuel injectors aren't leaking, rather common for these early jecs/bosch fuel injectors to leak from the body and they must be replaced they can not be repaired.
whether it's a gtr, vl commodore, nissan exa, very common now they are getting on in age...
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4664837
Hey guys,
Cheers
long
Hey LoNgStAr!
First time poster for me in the NSW thread as I'm from VIC.
As some has already said on here,
Check your fuel injectors to see if they are leaking or not... If they are not leaking, run a can of injector cleaner next time you fill up your fuel tank.
Check you O2 Sensors out with your mechanic.
Check for any leaks in the fuel tank area. Fill up a full tank, take it for a drive, come home and park it over night as next morning see if there is any fuel stains around the rear area... Get mechanic to check it out... Look under the car for any leaks too.
350kms, that sounds low but not bad... I get about 250kms from half a tank and about 450kms - 500kms full tank.
See how you go.
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4666161
Hey long,
It's basically gonna be one of what's been said so far. Either injectors, fuel lines, 02 sensors or a leak somewhere around the fuel pump cover itself. Yes a computer will help with fuel consumption but that's an extreme measure just to try and fix the consumption part.
On another note, got any pictures of how the xd9's look on the car? Love these wheels on gtrs... =)
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4668503
  • 3 weeks later...
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
