Hey people,
I have an R33 GTS-t manual S1 Skyline. Is it worthwhile persuing change of the gearbox from series 1 to series 2 or both gearboxes absolutly the same? Someone told me that series 2 gearbox has a different gears ratio. Can anyone confirm that?
Cheers,
Eugen
https://www.sau.com.au/forums/topic/275387-r33-s2-manual-gearbox/
hmmm anybody else opinions? anybody has speck sheets for series 1 and series 2 ECR33 skylines?
Gear ratio exactly the same... Only thing i know for sure (from first hand experience) is that you can't get spare parts for series 1 gearboxes. For example i wanted to change 1st-2nd synchro. Called nissan and due to a supersession i needed to replace all synchro's, selector and a long list of other things... Trade price quote came to $2600... In short the series 1 is fine as long as nothing goes wrong in it...
Thanks guys, so there are a better gearbox but not much point upgrading until mine fails completly. I leave it alone for now! Sky, any ideea how much u suppose to pay for a good quality second hand gearbox series 2? Anyhow if the parts are different inside and do not fit from one to another means they are somehow different. RIGHT?
Eug.
i cant fkn break my box...ive tried...
N where did u get trade price of $2600 from? ive been quoted by 2 separate reconditioners, less than $1300 for synchro and bearing replacement for my whole gearset (bar i give them the box out of the car).
Really depends what was wrong with his box to get a $2600 quote. Synchros and bearings are basic reconditioning, and yes you shouldn't get quoted more than about $1300 for a recondition. He might have damaged parts of the gearset/cluster though, which is code for "give Nissan your credit card". Or do the smart thing and buy a second handy in need of a reco :P
hmmmm if you pay the same money and u have to get it replaced, would you like to have one stronger and with buggs taken out or you don't care which one you get?
E
When I actually manage to break this box, then I'll worry about it :blush:
Eug.
they usualy sell around $1500 - $1800
in saying that though i picked up all these:
s2 90,000kms box with nismo short shifter
1,000km old exceedy heavy duty clutch
new flywheel
and other bits to convert to manual (tailshaft, pedals, clutch master & slave)
for $1,500
so you can get a bargain if you look around... i got mine from a dude that was wrecking his 97 s2 locally.
If i could only get the synchros it would have been way under 2600... But i due to supersession i would have needed to replace a long list of parts... As soon as you tell nissan parts that you have a series 1 box they tell you to sit down before they give you the quote.
got my Series 2 97 model box with tail shaft and all the usual parts for 1100-luckily it was in adelaide (where i live)....
As far as iv seen, the differences are minimal, when it comes down to it, if you could find a series 1 box for considerably cheaper id be going for that instead of a series 2 box. The differences wont allow you to break the box with any reasonably modified car.
Is that even possible?
Every RB25t box that I've seen for sale is ~$1500 and none specify series 1 or 2.
I am still sceptical as to whether there are any differences. I can however see there would be a difference in bellhousings between R33 and R34 boxes due to the pull type clutch in the R34.
It was listed as 1150 (i think), the guy had a 32, but had been defected. He had both an AUTO 33 and Manual 33 Series 2 97 box. Car had 78k KM on it. I asked for 1100...he said yes, on the proviso i took both boxes...still have the auto box lying in my enclosed trailer :laugh:
http://www.skylinesaustralia.com/forums/R3...&hl=Gearbox
thats teh link for the sale haha
Bubba,
my thought process at the time was that considering how hard a 25Box is to break, the likelihood that this gearbox is a series one box in a series two car would be pretty small. Hence why i ASSUMED it is a Series 2 box out of a 97 series II R33 with 78k Km. I thought it was pretty logical to assume, but i see where your coming from. I think the seller just said it that way, to give history of the gearbox etc.
Either way, even if it is a series one box, as you have said the differences are minimal, and ill be damned if i break this box.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
