yep been discussed, but i think Nissan deserves a "WTF were you thinking when you designed the back!!, if you wanted to copy a car then WHY oH WHY did you chose one of the wost looking suvs of all time!!(Subaru Tribeca)" moment.
lol but yeh, its like two people designed the car, the front by a loyal employee and the back by an evil one sent by the Soobies.
actually the interior styling are pretty much standard across V35 Skyline, the crossover (or Infiniti FX in USA), and the new release of Nissan Maxima (saw the ad on tv tonight)...
if you like the interior and can't wait, go to your local Nissan dealer and buy a Maxima :happy:
