  • Replies 714
Posted Images
why not come and join up ?? :)
No point for me really. I work every weekend, so attending events is almost impossible, getting time off for this car show was hard enough. As i see it, me joining SAU:SA would be a waste of my money and peoples time.
i dont think you would honestly be wasting your money or peoples time Abe, not every member of SAU:SA is into doing car shows and what not.
I am not going into this any further as i don't want to start an argument (what i originally was typing may have started one). If i am allowed to the meeting, yes i will grab a entry form from you, if not i will have to get one some other way.
I am taking a mate with me and we are sharing a room. So the room is $100 a night, comes with 1 double and 1 single bed, i am staying the Friday and Sturday night. I am awaiting a reply for just 1 single room for Krishy.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
