  • Replies 714
Posted Images
  • 1 month later...
Since Cara has decided to stop being the SAU:SA Events coordinator, are people still wanting to go to this event? I am still keen, but i may not go if others aren't going. I have already booked my accommodation, and booked the time off work, so i don't want it to go to waste if no one else is going.
He is our token drunk to colour in when he passes out .... he has to come! Maybe he will actually stay sober enough to go through with picking up with a local hottie - unlike Kadina :D
Lol.
Shhhh, you shouldn't have mentioned that. I was trying to lure him into a false sense of security, so he could get him drunk again :D.
Yep still going to this show....keep the bookings abe
Kewl, well i will still go then. Does it matter that i am not apart of SAU:SA?
you will be asked to drink and compete with our SAU tour drunk (LUKE ENR) and at that point shit be done that can never be spoken about....
nah just kidding bro your all welcome
guess I should book a spot hey ???? the car will be transformed a tiny bit by then .lol
hey luke I still have about 20 of your photos on my phone..maybe I should download them ..lol Ive been nice not to post em up on the forums..lol
so is everyone coming up friday and leaving sat or whats the plans ? where should I stay I havent really looked around loxton only passed thru it from broken hill and berri
Im going up Friday night, staying for 2 nights and coming back Sunday. Ive booked in at the Loxton Community Hotel/Motel. It was pretty full when I got my room but maybe give them a call incase they had a cancellation.
Where do I get paperwork for entering the show?
hey dion I got mine from Cara on dyno day but I can copy it and email it to you tonight if you want it ?
Cheers for that guys! :D
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
