  • Replies 714
Posted Images
As I said to Ben on the phone I am most happy to supply my basic shade like we used at Kadina, but then thought about this:
http://www.dealsdirect.com.au/p/white-part...-walls-windows/
If we all chipped in and bought this, then SAU would OWN it. So a once-off donation from the people going of about $15 and it can be used for future events for free. Looks pretty awesome, is much bigger than mine (and presumably properly waterproof), and has side and rear protection.
Sounds good to me - can you order it andrew? I'll be happy to chip in
-D
call it bullshit by only quoting one post D.....not very smart, is it????
Ben i might have a mate coming with me as well....so will let you know about the breaky for him as well mate.
I'm just lazy - not singling you out but there it is.
No problem re ur mate
-D
So as far as detailing/car washing is concerned, Ive done a quick search and came up with these:
Loxton Quick 'n Easy Car Wash
Auto bay, manual bays, vacuum and fragrance bays, car detailing service available. Water-wise car wash using recycled water. Open 24 hours, 7 days a week.
Bookpurnong Tce, Loxton.
Ph: 08 8584 5477
Riverland Mobile Detailing
9 Baynes St
Barmera SA 5345, Australia
0407 781 772
I would be happy having my car detailed here, and then just taking it to the DIY carwash up there and do a quick touchup. Or else we could ring that mobile detailer if there is a few of us but not quite enough for your detailer Ben.
ahh, good work Dion :)
yep gw - we'll enquire about these cats once people have paid their entry forms and lodging
pay entry 1st > pay lodging 2nd > pay detailer 3rd
I'm not even going to book a detail job if folks haven't got their entry or lodgings sorted :)
Today I got the SAU banner and 2x nissan flags off cara - Thanks for arranging xport cara, I appreciate it!
I'd like to find a place that leases flagpoles, or find some place I can possible get some earth-bound sticks with clips.. any suggestions? my front lawn is avail as a testbed if anyone has any kooky ideas
-D
yep I bought it at that special price this morning :)
awesome work :happy: ill drop some cash off to ya on behalf of Abe and myself (he already gave me cash last week at villis for the tent hire, have to get him some change tho)
In other news, Cara sent the banner and flags down - now I just need to find a place that rents portable flagpoles cheap, unless anyone here is good with metalwork/woodwork
-D
-D
Dont worry about the change, put it towards the tent :)
and don't worry about getting the cash to me .... at the event or whenever we bump into each other is fine mate .... it was only around $148 delivered, so sits on the Visa with little consequence :)
i will be pressed for time to get the car back up and running for this show....going away isnt helping either....and damn HYPERGEAR turbos not helping at all....
heh
garrett or gtfo - does this mean you might be pulling out?
-D
and don't worry about getting the cash to me .... at the event or whenever we bump into each other is fine mate .... it was only around $148 delivered, so sits on the Visa with little consequence :D
OK cool, that makes things much easier, I'll fix u up for myself and Abe on the weekend
Folks - pay me for brekkies on the day, pay Andrew for the tent when we get there. Easy as.
Any updates on entry forms? Who hasnt yet paid/lodged their entry?
-D
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
