Theres nothing wrong with 'dosing' and it won't wreck your turbo, as long as you're not being like a VL driving dickhead and deliberately stuffing around with your intake piping to get the most ridiculous noise possible.
I had a Turbosmart Atmo BOV originally fitted on mine, which got a lot of cop hassles, so went for a standard BOV blocked off, and it sounds a LOT better than a standard recirc BOV, which again sounds better than one of those utterly gay need for speed style SSQV's.
  • Replies 57
i have a 2835 with a stainless induction setup, but in a cold air box with a CAI.... when i blocked off the bov to rule it out as a possible leak, it made the full on VLT dose.....
put that bov back on REAL quick....! :)
dude... the Polarizer was the part which made the HDT's so special! That and having to run 22psi in the tyres for it to work, and not tampering with or removing it, so that the positive vibrations could flow throughout the car and turn a family sedan into a track warrior! I'm still hanging out to drive a Polarizer equipped HDT to feel the awesomeness :blink:
I dose all day all night on 18PSI, haven't seen the turbo die yet. Stock intake pipe, stock crossover pipe, GReddy TypeS BOV wound in so hard I might has well not have it there.
and no, I didn't use a HKS SSQV, that has no effect to dosing, unless the piston snapped and the BOV is now not functiuonal
dose ftw.
no BOV, big front mount, steel pipe off the turbo. the loud high pitched dose is normally curteousy of a 2.5" straight pipe straight off the turbo, when you start adding bends, and go to bigger pipes, the sound normally gets deeper.
the AFM being moved to the cooler piping is to stop stalling from the air reverberating through the AFM
  • 1 month later...
What the hell is that noise? I've heard it twice now, both times from VLs. Is it some tricked out BoV?
If you ask me I think it sound ridiculous. My girlfriend was in hysterics for about 10min as we drove beside this thing.
Thanks.
i dont see how its so funny? it sounds mint
To the ignorant it sounds like a really wimpy/silly sound to come out of what looks like a tough car.
Like WRXs and EVO's, except they look like a girl's ride with girly ricey sneezies.
Do agree though, that fully hektik sound doesnt match the VLs. Something you'dexpect from Jap imports?
lol they are morons then.
+1
if that's all you're buying the car for then... fail.
ive had mine blocked off for a while now, doesn't make high pitched noises, just a clean whoosh sorta flutter. reason why i have it is that i noticed through hills/track, when changing gears it holds more pressure in the pipe and you get faster spool in to next gear but only high up in the revs as the air gets trapped and not released straight away.
lots of people say different things, this is just form personal experience.
Edited by SkyHi_33
here is my old car fluttering and doing its thing.
fluttered the entire two years that i had it. absolutely no damage to the car/turbo whatsoever. it fluttered so loud because of numerous induction mods and very high boost. factory blow off valve gave up but replaced with an aftermarket plumb back.
Edited by DrewII
    • Yea I could, but it is amusing how shit a stock seat and belt are
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
