  • Replies 372
Posted Images
I thought he was a bundy man? or have I been away that long he has downgraded? :D
NEVER been bundy man .. the sphincter of the universe for life :P
anyone else getting as excited as a bunbury man who has found a second tooth? ;):P:banana:
Hope your driving is better then your jokes :P
if there's an opening anywhere someone let me know...in case a Massa's happened, I'm your Schuey :D
You'll have to be there for qualifying.... maybe throwing some kart parts you can find randomly into on coming participants :devil:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
