Wonderful news to make my weekend worth while.
I've just been advised that as of next Wednesday July 1, I will be without a job. My current job is in IT, working on Oracle databases, Oracle Forms, SQL*Plus.
If anyone knows of suitable work please let me know via PM.
TIA
the visually challenged moose
https://www.sau.com.au/forums/topic/276539-work-wanted/
I was thinking of subcontracting someone to develop a few Oracle DB procedures to work with an online application I'm developing for a client, still waiting on the tender to be approved first though, but if it comes through, I might have some freelance work?
https://www.sau.com.au/forums/topic/276539-work-wanted/#findComment-4682542
SQL Server db admin here.. in 2005 there's visual studio, but you can still write in t-sql which is preferable. Had to do a oracle to sqlsrv migration recently, and that was a pain in the ass. But i'm sure you'll be fine as you sound pretty experienced in oracle.. and yep sqlserver just another rdbms.
https://www.sau.com.au/forums/topic/276539-work-wanted/#findComment-4691948
i mean if someone is going to pay you to do sql server and code etc then go for it
but as far as managing it, adminstration of it etc oracle is better and bulletproof on solaris
SQL server is easy to admin, but there are some limitations of things you just cannot tune.
Where in Oracle, there is much more to tune but it also relatively harder to admin.
Paulr33 have you worked with SQL server? Or just Oracle?
90% of my work has been with SQL server admin, but I've programmed in both SQL server and Oracle, I'm not a full-time DBA though....
https://www.sau.com.au/forums/topic/276539-work-wanted/#findComment-4694699
From a programming point of view, in the past Oracle used to be awesome due to the fact that you could program in triggers, stored procedures etc. But these days MSSql and MySQL have caught up to the tech. The only issue is with the OS's they're implemented, but even that these days is pretty good. Personally the only thing I've come across that the latter two engines suck at is that they're slightly slower in calculating hashes and reindexing etc.
https://www.sau.com.au/forums/topic/276539-work-wanted/#findComment-4694763
have done both, not as much sql server
it just seems to standard and out of the box
and any retard can get them self into trouble really easily from assumptions etc
whereas oracle you really need to know whats going on to tune it properly
very poweful when done properly
we did an oracle 10g rac cluster on solaris, it was ace
https://www.sau.com.au/forums/topic/276539-work-wanted/#findComment-4694904
  • 3 weeks later...
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
