Hey guys just wondering if anyone might be able to help....because its doing my head in....
There is a large roundabout outside my work, with a large tree growing in the middle of it....
Nothing unusual about that.....HOWEVER....
Thismorning when i got to work, there was a wooden sign hanging from it, stating -
"Thar maybe treasure 'ere", with an arrow pointing down....There was also an empty
bottle of J & B Scotch Whiskey hanging from a piece of rope from the wooden sign....
Also there was a stick stuck into the ground below the sign, with some fresh dirt around
it, however this dirt looks to have been placed there rather than dug up...
Anyways, upon further inspection, i could find no possible treasure, though i did find a
hammer on the ground near it, which is a bonus. I also took the empty bottle. LOL.
So what do you guys think?
https://www.sau.com.au/forums/topic/277225-thar-maybe-treasure-ere/
yeh i was worried of tapes being around so i made someone come with me haha!
a bit of effort though...at least i scored a hammer!
cant really see the humor in it though....i mean its not like i turned up with a shovel
or anything....you know what i mean its missing the spark to the joke....
not a lot, i guess
but if it wasnt written by pirates, i applaud the educated people for their authenticity :)
So there was no pieces of eight ? Bugger.
QUOTE (zei20l)When I get sad, I stop being sad and be awesome instead. True story!
Nice like that :)
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
