Hi everyone, got a very interesting proposition for all of those R33 Skyline Owners out there with sunroofs who are wanting a 4 Point Half Cage for their R33.
I have spoken to David down at Brown Davis Automotive as I am wanting to purchase a bolt in half cage for my R33 which has a sunroof.
He will be using my car as the dummy and informed me that he can offer me a discount if I have 3 or more done all together.
These 4 point cages (half cage) are full CAMS approved and are powdercoated, have the harnesss bar running across the back and the diagonal bar running from top to bottom.
Price for one:
$1,100 fitted (letting them remove and refit all your trims)
$1,000 fitted if you remove the trims before you take it there
Price for 3-6
$800
Price for 6 or more
$700
Now, these are for R33 GTS-T WITH SUNROOFS! He said he can do the same deal for anyone who doesn't have a sunroof, as long he can use one car to do all the measurements.
Group buy will be running from 1/7/2009 untill the 15/7/2009 so please pm me with some contact info if you are interested.
Payment can be made directly to Brown Davis but I will need a deposit so I can give him the go ahead and produce these half cages.
If your uncertain you can give him a buzz and have a chat to him about the whole group buy.
If your from interstate we can still have these made for you and posted out to you at your expense.
They are located at 47 Holloway Dve, Bayswater, Victoria
http://www.browndavis.com.au/
http://www.rollcage.com.au/rollcage.html
Cheers
Dean
0403059467
Edited by DinoPanta
are the cages ADR approved?
could be interested in one without sunroof for r33.
Brown Davis cages are ADR, and more importantly - VicRoads approved.
Can't go wrong
also interested if it is a bolt on/removable cage. Is it steel or chromoly? brown davis do 2 types....
The FIA has banned CroMo from being used in cages, so if you want it to be legal in the future and what CAMS may implement in light of the FIA banning CroMo, best to stick with cold drawn seamless steel... CDS steel is also safer and cheaper so there's no reason to go CroMo, especially in a road car.
i noticed in the images that there is a 4 point cage in an xr6t that retains its back seat. i know its a sedan with heaps more room but will they be made to accomodate a back seat?
cheers...ben.
Would he want to do an R32 without sunroof? I would be tempted to sell my 7point cusco cage to go down this route...
are they bolt or weld in?
Edited by RB_Ryan
Guest
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
    • Looks fancy But after having a look, prior to its installation, I noticed that the yellow looking power steering reservoir would look crap next to this So I have this incoming..... Much cheaper than the Moroso and has great reviews (yeap, it's a Moroso knock off)
    • Can we place bets? My money is on there is always the option to use the 1 way profile. So the diff is either 2 way and 1 way, or 1.5 way or 1 way.
    • I also used Knox driveshafts when I the slip yoke T56 to the 3bolted TR6060 type. I believe I was one of his first jobs as it literally changed hands when I was there, started by the old owner and finished by the new. Everyone seemed pretty great about it. So wasn't shy/seemed pretty knowledgeable when dealing with weird custom people like me.
