hey guys
ive had really bad fuel milage (approx 280kms a tank)
anywho i was thinking it was the o2 sensor, but when driving home from work i watched the stock boost guage closely.
at normal cruising, it sits close to -6 but once a bit of throttle is put on (below 2.3-3000 revs) it moves up to 1/4 mark and somtimes 0.
am i getting constant boost? i know a turbo works on exhaust gases but i dont know much about the factory boost guage.
https://www.sau.com.au/forums/topic/277342-think-im-gettin-constant-boost/
your only getting boost when the gauge starts going above 0 into the positive area, sounds normal to me.
try new plugs, fuel filter, clean out you throttle and AFM and swap your O2 sensor, should get you out of trouble
yeah it is, running stock boost too i think so 5psi or whatever it is.
just wanna know why i got such bad fuel consumption, i know skylines are a performance car but 280kms out of a full tank still?
and thats not floggin it every time either
^ exactly - the list is long.
The answers are plenty however - please do a search.
Its been covered pretty well as you could probably imagine... being fuel economy is a reasonably big problem for most people
sounds like the turbo is spooling up but, even when under the 0 in the negative side
yeah my car does the same thing, but its just the pod filter sucking air in, you can tell the difference between the induction and ur actual turbo spooling
Do all your regular maintenance as per the many threads covering this article, don't bother trying to work anything out until it's fully serviced then go from there.
An important thing to note is cold and hot starts as was mentioned above. All cars use more fuel when running cold so if you;re ot trips your fuel economy will suffer badly.
Get used to high fuel consumption. 280km is low for sure but your never going to get fantastic results. I went from a 3L v6 magna to the skyline and the magna despite being 500cc more drank SO much less fuel.
Also given that you have had the car for such a short period of time, is it possible that you have just been enjoying it quite a bit, ie giving it a bit more throttle than normal, going for short cruises around the block etc? When I first got mine the whole turbo thing was awesome fun but led to driving in a way that was very harmfull to the consumption.
as mentioned before ^^^
just give your car a decent service, change all the fluids, spark plugs, give the afm a decent clean....warm it up and then go for a nice drive....dont thrash it just drive it normally and let things smooth out.....you might notice a bit of a difference in consumption....
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
