  • Replies 477
Not sure what turbos the Hi Octane 34 runs but im pretty sure it runs a AWD RB30
yeah its an rb30: http://hioctaneracing.com.au/news_RB30.html
your signature is a crack up & i bet some people really believe this as well HAHA
  • 5 months later...
quick update guys - i decided to upgrade my n1 oil pump to the nitto oil pump as it wasn't up for the task.
greg @ proengines also made a custom collar to better suit the oil pump.
i'll be taking the gtr to crd hopefully this sat for a quick health check :happy:
hi guys,
just did a road test in a back street & recorded the results on my blitz ebc (rob @ rips got me thinking on this):
3rd gear: 1bar boost @ 3800rpm
4th gear: 1bar boost @ 3500rpm
5th gear: didn't have the room but would 'guesstimate' 1bar boost @ 3200rpm
mr rob ward, your t04z setup which makes 1bar boost @ 3000rpm, what gear is this done in?
i should also note that my setup has been tuned for top end power, im sure if i asked jim @ crd to tune for mid range my revs would come down even lower @ 1bar boost...
regards,
marko
i dont think you could beat the stock extrude honed manifolds...especially if they are black coated.
Yo dirty man, do you think it's worth the extra money for a set of aftermarket low mount manifolds- compared to a set of honed and ported N1 manifolds?
I'd like to keep the N1's (I have them all done allready) but if there are reasonable gains to be had I'll ditch them... I don't want the ex-mani's to be the restriction.
I know you were running aftermarket manifolds with the GT-RS's.
2.8, head, cams, greddy plenum and 50mm tb's, GT-RS's....
Cheers
Justin
There needs to be a 2.8 section...
i think i can answer on pauls behalf as ive had this coversation with him in the past...stock manifolds are much more reliable & just as good if not better than aftermarket items.
mark with his hi octane gtr was using tomei manifolds then went back to stock ones which were matched & honed for better response, as per his interview on ignition dvd
Thanks marko.
Yeah, I'm really trying to stick with cast manifolds. I'd hate to have to change manifolds after a few thousand km's because one cracked... unfun job.
I've run 400rwkw with stock-stock manifolds in the past... un ported, honed or coated.
I seem to ask Paulie alot of qn's because he's run good numbers with GT-RS's... I'll be running GT-RS's on the new stroker motor.
Anywho... thanks for the reply.
Cheers
Justin
Cheers
Justin
No...spend it somewhere else
  • 1 month later...
hi guys,
i have ordered a new set of splitfire coilpacks as my factory coilpacks started to misfire. tell tale sign was that 1 of plugs was very dark (thanks for the guidancec paul).
whilst im doing this i looked at my plugs...i am currently running ngk pfr7a (1.1 gap) & have done 1000km with them. should i just clean them (with petrol & toothbrush) or should i replace them as they did clean up well.
my tuner recommended i go with pfr7b platinum if i update them - the problem is that nobody in sydney stocks 7b's let alone 7a's! this is head fark & a 1/2 :D why is it sooo hard to buy a set of plugs???
hi guys,
bcpr7es marko...made better spark and more power with these puppies than any platinum plug you care to name. I run coppers in the race car too...but not 7's.
invest in other mods such as alcohol
Baah... Alcohol is for drinking
Gasoline is for washing parts and
Nitro is for racing!!! ha ha ha
Yeah, I was thinking about methanol a while ago, but it really dosn't go with my street car build. Also E85 isn't available in Tas, so I stuck with the ID1000's instead of the ID2000's...
Oki doki paul. Better spending $20 on a set rather than $150, its a win win solution
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
