  • Replies 477
can anyone get these made up?. i would love that set up on my 33gtr, or is anyone selling one?. bernie
Im having one made up along with a slightly different design.
Can get more made but shipping would be a pain/expense
I got a price on them which I think were 400-500 for fronts alone.
The local 'race brakes' are only 150 for fronts, my mate who was doing 1:07 at wakefield in a stock r32gtr did back2back testing with a no. of pads including some jap brands and bendix ultimate, in terms of braking power and wear the race brakes came out on top.
If anyone is interested I can find his email and post it here?
Bernie - that is a custom job BUT the apexi n1 system is the same with 2 x 3inch pipes and straight off the shelf
cheers marko, we dont really have exhaust people here that can mandrel bend and supply silencers of that qaulity, what would one cost made in oz and shipped to me..lol any takers.lol
my hks preist would probably give me 400 uk back to spend
Edited by rockabilly
To get a full system done in 4inch including front pipes is approx 4k aud, now to run 2 x 3 inch pipes I'd assume would be more than as it is essentially 2 exhaust systems + shipping which I would think is 500 aud.
Bernie, what's the latest with your donk :merli: nothing worse than an engine failure, other than a funeral
Try Racer Industries in Bris. Mine cost $276/pair. The 4-500 sounds like some more serious Mu pads.
Edited by Scooby
quick update:
my new brake setup feels phenominal...the combination of refaced factory rotors, 'race brakes' pads & motul factory line brake fluid gives me all the confidence i need, dont know how long they would last on the track though with over 400awkw :D thats ok, i'll just turn down the wick on track days (if/when i get out there)
for the 1st time, i activated my abs with fark all pressure on the pedal haha
i have noticed that my pedal sinks lower to the floor though than previously, is there an adjustment to bring in the contact point a bit earlier?
cost. if i upgrade my braking system though, i will get k-sports all around which will set me back about 4k.
refaced discs = $100
f&r pads = $300
brake fluid = $70
i also dont think i need huge brakes for the street - the likes of duncan who race in production advises that the factory gtr brakes are quite good when setup right.
i know with the power i have i should get bigger brakes - for now though, im wrapped & dont see the requirement :D
come to think of it - if i ever break this box like i did in my other gtr, i'd probably just get another gtr box exchange unit...these days u can get them for under $1000.
what is the cost to get an os gearset fitted in a box (i'd do the r&r myself)?
well its $ 2,848.10 + shipping for the 5 gear kit from RHDjapan at the moment, plus what ever it costs to have it fitted into the box/replace synchros/bearings (i remember something about the R32 box needing some R33 parts as they were stronger/better?)
Well, if you break one and spend another $1000 on another stock unit it makes sense at least to me to get the upgraded box cause the next stock one will just break again. That's my thinking anyway
when I enquired for my box I think it was something like 1500?
Then of course a donor box (350 or so for a worn out one) and a gearset (price of course depends on how wild you go)
well if it was going to cost me 3kish i'd definitely take that path. that is very cheap!
i should speak to terry @ award diff for a price on fitting the gearset.
i always thought it was up around the 7k mark?
apparently the input shaft also needs to be upgraded as well on the r32.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
