Hey Guys,
I got my RB25 Highflow (Hypergear ATR28G2)and some other goodies tuned the other day by CRD and pulled 235rwkw. Now Ive come across a VG30 .63? rear housing from which I have been told by Stao at Hypergaer "should" get me around 250-260rwkw with the sacrifice of course of a bit of response. Maybe 400-800rpm laggier than it is now.
I do admit that I am a response whore and dispise lag....BUT......the need for more power is already hitting me so I was wondering if you kind people could look over the two dyno sheets attached and tell me where you read boost to be startingat and where full boost is at what rpm's.
It may be a noob thing (and if so please forgive me :() but im not sure I can work it out by the two printouts I have.
If anyone out there has tried the .63 Housing on their RB25 Turbo Im interested in hearing your opinions.
Thanks in advance
P.S. Ignore the breaking down at the top end, the coils collapsed but it is now fixed with new Yellow Jackets
https://www.sau.com.au/forums/topic/278164-help-me-read-my-dyno-sheet/
Fullboost looks to be reached around 90kph. That would be about 3500rpm in 4th I think. This does not tell you all that much about lag. As a turbo that boosts later in the rev range does not always have more lag, and vice-versa. I doubt a change to 0.63 A/R would reach full boost more than 200rpm higher, and it wouldn't have much more lag considering the 0.48 has a big wheel in it that isn't really suited to it.
Can you get them to give you a graph with the revs on the bottom axis?
Would be much easier to work out then, with current graphs you will have to convert the speed to revs
Yeh ill try them again. I did actually ask for that and the bottom sheet is what they emailed me
Hey thats pretty good news 200rpm is very liveable. It doesnt "feel" at all laggy at the moment and im pretty happy for an $800 turbo so it may be worth giving the .63 a go then?
IMO there is more midrange still to be had with your current setup especially once you get your boost holding firm/stable as that will be hurting the whole setup.
Around the 100km/h mark its really being hurt by the boost drop, slows the proceedings up as a whole, and the top end drop is also a problem as it looks clearly like boost control rather than the turbo being out of flow.
What you need to ask yourself more-so is... are you really going to notice the 20rwkw?
Answer - yes, but not really.
And that leads to the next question...
Is it really worth the effort for a minor difference? IMO No.
To pull the turbo off, send it away, new housings (im assuming a near rear wheel) etc etc, its simply a waste for the end gain of a tad more power and less response.
If you rip it off - do it right and then go for 40rwkw more with a GT3071/3076.
I recommend fixing your boost control, once you see the improvement there i reckon you are likely to forget about going for a marginal power increase.
Thanks R31Nismoid (Ash isnt it?) I was told by Jim that the top end drop was due to the stock coils breaking down and thats why he couldnt control the boost any better, and the next day I couldnt even get out of my driveway they were so bad so I just took his word for it. Since i installed the Yellow Jackets it has been running better but your saying I should go back to the Dyno??
With the new coils creating a better "Spark" will that have any aid in controlling the boost? Or am I way off on that one?
The ATR28G2 is in similar spec a GT3071 52T
It will be making lot more then 20kws with heaps more torque in a .63 rear housing. You will definitely notice once its running.
Hoo want me to proof it can make lot more power and hold boost straight in bigger turbine housing?
Ye mate. Get it back on there if that's what the problem was... the early peak to 18psi and the drop back, and then the rise (just before 100km/h) is more important though. I still reckon that's likely to be boost control though.
You'll soon see when the car is back on the dyno with new coil packs. You should see a more top end. It will feel better with the extra 2-3psi up top as any car that drops boost up top feels lazy compared to its midrange.
Now its sorted, have another go and then see if you aren't happy.
Peak power isn't everything and if you truly do love response with that midrange and top end both fixed up on the turbo you have on there currently it will be much better
End of the day 240-250rwkw (once back o the dyno, thats my guess) - with the response you have is going to be a very fast car... im just against you spending so much more for not a overtly large gain over what you have now
Thanks for the tip, Ill get it back on there and get them to sort the boost control while they are at it. Once ive got it running right ill then make up my mind
"It will feel better with the extra 2-3psi up top as any car that drops boost up top feels lazy compared to its midrange."
I know exactly what your getting at here, I noticed it on the Freeway on the way back from the cruise on Thursday but I thought it was just me...Doh
Didnt want to push my luck twice with the speed thing to feel it again
Dave The boost dropping is not because of a boost controller issue.
You need to understand there are 3x forces controlling actuation. That is inlet manifold pressure, the spring load, and exhaust manifold pressure.
Lets discard inlet manifold pressure in this case.
The wastegate flap is forced shut by the actuator spring, and once the exhaust manifold pressure exceed the spring load it will force the wastegate flap open. At that point you see a "boost drop". That is not some thing you can control with a boost controller.
The only way to solve it is to lower manifold pressure which means a bigger turbine housing.
Bigger turbine housing increases exhaust flow, reduce exhaust manifold pressure, temperature and lower compressor speed. Which allow better turbo efficiency and torque.
This also explains why a ATR28G2 have made more power and better torque in a smaller engine (ca18det), with a bigger turbine housing (about a .60 T3):
On a well designed/assembled turbo there should be no boost drop as the gate opens if correctly regulated by decent boost control setup. No decent graph in ANY of the dyno stickies shows or backs up your claim that it it is not controllable.
Have a look @ the graph - 80km/h suddenly boost falls off - If that's the turbo's fault... then its a crap turbo, simple as that.
However I suspect boost control - and funnily enough boost control was a noted issue from the tuner :sorcerer:
That is the main issue here.
The graph of a 1.8ltr 4cyc doesn't really help a lot when we are talking a 2.5ltr 6cyc...
Motors have different flow levels, rates and so on. Not sure what it's there to prove exactly and it doesn't really explain much
All your telling him is that the only way to fix his 'problem', is to spend more money. Its not actually a problem yet as the car isn't running 100% to rule anything out.
So selling/trying to sell whatever, its wrong until you actually know that where the setup is lacking - is sorted.
Ok thanks guys, Ive opened a small can of worms here buy the looks of it.
So from what I can gather my best plan of attack (and cheaper) is by process of elimination.
Now tht I have fixed the breaking down coils problem get back onto the dyno and see if it helps with the boost control.
Only if that does not work should I then look at the .63 rear?
I'm kind of a little confused now
Ash, I get what you said about changing turbine wheels etc with the new rear but Stao told me that it's just a matter of machining the VG30 rear to fit the ATR28 profile and that's all I will need to do, no rebalancing etc
Are you saying that that is not completely correct
So would that explain why my 2535 will still drop boost off even when the actuator isn't connected to vacuum? The exhaust manifold pressure is overiding the spring tension?
Ash, Compressor map of a turbo would not change in identical housings. You can only pass out of what the compressor can suck in. So you can not have "Greater flow" unless you have a bigger compressor wheel, which does not suit in this case. The current flow limitation is from factory turbine housing. So replace it to increase flow. simple.
Yes. Fix the apparently broken stuff (as there is no downside to that) before you look at changing the turbo, which will reduce responsiveness. Trying to tune with dodgy coils or boost control is going to waste your money.
Ask your tuner if he thinks that your boost control is adequate (tho he might not be able to tell for sure until he runs it with the fixed coils). Since Nismoid reckons the control is bad it might be worth upgrading that before you go for the tune, so you wont have another wasted trip.
What are you using for control now?
I'm only just starting to learn about boost control as i'm having problems of my own, but;
- If the exhaust pressure is opening the wastegate, doesnt that mean the actuator spring is too weak? I would have assume that the spring would be strong enough to hold against considerable wastegate pressure, as the you really want the actuator diaphragm to be the primary force against the spring, since the pressure against the diaphragm is something you can control via the boost controller.
Adam, I am running a HKS adjustable actuator (set to 15psi I think) and my controller is a greddy profec b spec 2. Both were installed and setup by CRD.
So CAN the coils effect boost control as Jim told me??
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
