I plan on buying a new ecu in the coming weeks and I need a little help deciding which way to go. The car is an R32 with RB20DET and i've just installed a larger turbo, new manifold, external gate, cams and ajustable gears, ebc and a few other things.
I'd been planning for a while to go with the Nistune, until i went and spoke to the only local guy that does dyno tuning. (I'm out in the sticks). He's never had any experience with the Nistune, but he's a Vipec dealer and has done a few of them in skylines now.
So what I'd like to know, is whether either of the ecu's have any specific advantages? I do like the advantage of my car being tuned locally by a guy with a bit of experience on similar setups, but I also like the price of the Nistune.
https://www.sau.com.au/forums/topic/278238-nistune-vs-vipec/
  • Replies 67
Yes the Vipec is a very decent ecu. You should go with it. However your tuner should also be able to tune a Nistune.
The vipec cannot be compared to the Nistune because they are totally difference ecu's. You can compare a power fc and a nistune like you can compare a Vipec & Motec.
They are totally different. one does the job and works okay, the other does the job and can make you breakfast.
If you go down the vipec route, you can pull out your ebc and use the vipec to control boost for just a added $130 part so you can get the vipec for a bit cheaper and have decent boost control as well.
for the price you can't beat nistune. it gives you all the features you need as far as being able to change injector size, afm and do full adjustment of ignition and fuel maps. and most of all, full installed and tuned it will probably cost a lot less than just buying the vipec ecu, which would then leave money in your pocket for other mods
There's one tuner in town and he does vipec. He's done a few skylines and some silvias and supras with vipecs now. His main clientel is v8's but he seems to be a decent tuner.
Other than that its a 5 hour drive to Sydney or 4 hours to Canberra.
Nope. I don't really mind towing the car to be tuned if i have to, but thats basically gonna add a few hundred bucks to the cost, and i still wouldn't have local support if something were to go wrong.
Vipec is starting to look like an attractive option! :laugh:
by the sounds of it vipec is the most viable option.. after you take in costs of towing etc if something goes wrong and so on.. might be a better to have a higher initial outlay of $$$ to save furhter $$ in the future "incase" something goes wrong
have you asked your tuner about power fc ?whats your plans with the car & whats the mod list, if its just basic upgrades, there is no need to go vipec.
Listed most of the mods in the first post. Its nothing crazy, but its further than the basic upgrades most people do. The turbo is a HKS T300s but i will most likely change that fairly soon anyway to something a bit newer and slightly more responsive. :pirate:
Thats pretty much the same train of thought i'm having.
in your situation with the distance i would go with what the tuner advises.
but i am looking at getting a Nistune soon, basically because my car is just a streeter, my tuner does both. and obviously i am gonna go the cheaper option because all i need is to maybe have the timing and fuel maps changed, and possibly allow for larger injectors and the Nistune will do that.
but i have heard great things about the Vipec, but i think $14k is enough to spend on a car in 8 months!
time to start holding onto my money
brez
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
