Took a half day and worked on the top end from 12-11. About half this was already done from a few days ago...
Pistons and rods installed:
Rods
Upgraded oil pump drive collar...
Windage tray on:
Oil pump on:
Rear main on:
Oil pan:
Oil pan baffles installed
Oil pan and motor mounts installed:
Other side:
https://www.sau.com.au/forums/topic/278761-pics-of-my-motor-build/
  • Replies 74
Posted Images
Water pump on:
Water pump pulley on
Alternator on:
Head on:
Intake manifold on:
Coolant pipe on:
Balance tube and IAC valve on (also a ghetto hose clamp in the middle of a hose trying to relieve a kink):
Kink fixed with prebent tube, waterneck on:
Injectors and oil filter in:
Fuel rail on:
Plenum on:
Cams in, with custom valve shims... :blush:
Timing backing plate:
Timing gears and belt installed. All tensioned:
Rocker covers on:
Another shot:
Everything else. It's not really pink in person, it's more purple. The camera just doesn't represent it very well.
Engine mod list:
•R32 Nissan Skyline GT-R RB26DETT
•87mm bore/3 angle valve job
•Wiseco 87mm Pistons
•Eagle Rods
•HPE Crank collar
•ARP head studs
•ARP Flywheel Bolts
•ARP Exhaust manifold studs
•EPP valve guides
•Ferrea Dual valve springs
•Ferrea Valve spring locators
•Ferrea Retainers
•Ferrea Locks
•ACL Calico coated main and rod race bearings
•Garrett GT35R .82 A/R
Tial 38mm WG
•Spitfire Coilpacks
•New OEM Water Pump
•New OEM Oil Pump
•Trust Timing Belt
•Powdercoated valve covers
•OEM gasket kit
•Cometic MLS Head gasket
•Polished alternator
•ATI 1000HP Race Damper
•Custom valve shims
Rest of the car:
Chassis:
• 1987 BMW 325IS (manual)
•Seam Welded
•Vito Antonicelli 10 Point Cage
•Every suspension member powdercoated
Body:
•Ireland Engineering Fender flares
•OEM Mtech1 Valences and Sideskirts
•Euro Bumpers, Dechromed
•Shaved Side Moldings
•Shaved Fuel Door
•Shaved Sunroof
•Custom baby puke paint
•Newman Engine Mount
•Newman Transmission Mount
•Custom Tunnel
Transmission:
•Modified RB26DETT Transmission
•Nismo Flywheel
•EXEDY 3 puck clutch
•Custom Driveshaft
•E30 M3 LSD 4.11
Fuel:
•Bosch -044 800HP fuel pump
•Seimens 870cc injectors, flow calibrated to w/in .5% of each other
•Summit 8 Gallon Fuel Cell
•Custom Fuel Cell hold down straps
•Custom Fuel Rail
•Braided -8AN Fuel inlet line
•Braided -8AN Fuel feed line
•Braided -8AN Fuel return line
•Aeromotive Rising rate regulator
•Summit Inline fuel Filter
•Custom filter and pump mounting brackets
Exhaust:
•Newman 304SS heavy wall manifold
•Newman 304SS exhaust
•Tial 38mm wastegate
Induction:
•Newman 304SS IC Plumbing
•PWR 24X11X3 IC core semi-custom endtanks
•Tial 50MM BOV
Cooling:
•MOXIES/Newman Radiator
Electrical/Management
•AEM EMS Speed Density Engine Management
•AEM UEGO controller
•AEM Serial Gauge
•HKS Turbo Timer
•New Engine Harness
•Kwikwire Chassis harness
•(4) Greddy warning gauges
Suspension:
•Ireland Engineering road race springs
•Ireland Engineering poly trailing arm bushings
•Ireland Engineering Poly Subframe mounts
•Ireland Engineering 22/25mm swaybars
•Ireland Engineering Camber/rear toe kit
•Bilstein HD Dampers
•New OEM wheel bearings
•New OEM F&R strut mounts
Wheels:
•Work VS-XX wheels (17X10, 17X8.5) Custom Offset
•Falken Azenis RT-615 275/40/17, 245/45/17
•Vorshlag 90mm wheel studs
Interior:
•Sparco Evo Seats
•Corbeau Harnesses
•Sparco 300mm steering wheel
•Rhinoliner interior and trunk
Brakes:
•Wilwood billet forged superlite narrow body, differential bore 6 piston calipers (front)
•Wilwood superlite 4 piston caliper (rear)
•Wilwood 13X1.1 GT48 rotor (front)
•Wilwood 11.75X1.25 HD rotor (rear)
•Cutsom machined rotor hats and brackets
•Massive rear hat, ebrake ring and bracket
•Wilwood Q pads
•New OEM ebrake setup (backing plate, springs, adjusters, cables, pads, actuator, pin)
•Wilwood Prop valve (installed next to driver’s seat)
•Custom Brake Booster
•Polished Master cylinder
•-4AN stainless brake hardlines
•-4AN stainless braided brake hoses
For more interesting engineering crap, check out this link where I made custom valve shims from scratch...
http://forums.gtrcanada.com/showthread.php?t=46321
you need to check the crank, where the crank collar is put on is the collar flush with the crank? this cost me a crank and it had to be replaced.
was it machined flush ? if not then it will need to be done.
Is what part machined flush?
The face where the timing gear rides or another side?
The crank collar came with detailed instructions from Horsepower Heaven, which was supplied to my machine shop.
What happened to your crank?
Edited by ctnewman
Wow looks good man. Keep us posted how you go. Couldn't keep the power steering with that exhaust manifold ay?
Haha, no, but I wasn't planning on putting PS in the car from the beginning. I really wanted an ATI damper with only the waterpump/alt pulley on it, but they said they don't make one.
not a bad idea...heard of them with everything from blown 350 chevs through 2jz's now rb swaps....im glad im not paying for the build tho!!!
planning to have it street registered or purely show/track car?
i'm gonna street the shit out of this car!
my other street warrior:
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
