Due to a cock up my engine let go on the way to getting it tuned today and i now have to rebuild the bottom end. Im struggling to find suppliers for RB20 parts mainly decent pistons.
Just wondering for those of you out there that have rebuilt the bottom end who have you purchased your gear through???
Any help much appreciated
Cheers Ben
https://www.sau.com.au/forums/topic/279026-need-to-rebuild-my-bottom-end/
Rocket
Precision international
Nason engine parts
Performance wholesale
Thanks Trent, i've already spoken to Matt from Precision International and they can only supply custom made parts so rules them out. I haven't been able to get onto the Nason site and waiting to hear back from Performance Wholesales.
See Performance Wholesale about ROSS Racing pistons. They do them for RB20 and are a great piston. They come with Mahle rings so an overall good package
Will do Dan, im hoping to get away with rebuilding it for around the 3k mark :D
Australian Precision Engine Parts in Wantirna South (Melb) - talk to Bill - (03)9887 1299
They can make a set for you.
$1500+ as a minimum to make custom pistons so would rather look at a ready to go option from ACL, CP etc to try and help keep costs down.
http://www.aclperformance.com.au/NissanRB2...rgedPistons.htm
you can get these from Repco.....good price too
Looking into the ACL pistons at the moment, will hit up local Repco for pricing though.
Why not just buy a wrecker motor with warranty and put a new water pump, oil pump and belts.idler / tensioner etc on it. All up it will be less then 2k for something that will be pretty reliable.
I was thinking about buying a long motor again and swapping everything over but you never really know what your getting, $1200+ (excluding freight) for an engine so it would be more than 2k by the time i buy everything else, freight it here and im still unsure on how many k's is on the motor, how hard a life its had and amount of boost its seen.
The car has been off the road for over 3years and i've spent ALOT of money on it already, this is the second engine that has let go and so far i've driven it less than 100k's on both of them. This was my own stupid fault and cant blame anyone but myself but id rather rebuild the bottom end so i know its all fresh, tune it up and re advertise the car and chalk it up as another experience.
Can i ask, how did it break? or more to the point.....what caused it to break?
I lent my PFC to a mate to use in his car for a hill climb but they kept having trouble with it and it wouldn't save any changes. In the end he decided not to use it and i put it back in my car (wasn't currently driving it as it wasn't registered) i took the car to get a rego inspection (had a base tune on it when the cams were run in) so it was just drivable off boost.
Unfortunately it appears it had saved changes as the injector setting were set back to stock (im running 555's) so it leaned out and went POP. Haven't pulled the engine out yet as it only happened yesterday but at a guess its a cracked/melted piston or broken ring land. Either way its FUBAR and im back to where i started 3 years ago with the car off the road with a blown motor :)
Umm, if your settings were back to base map and you have 555cc injectors, then it would run rich, not lean.
What exactly is the problem? Missfire?
Could have just fouled a plug. You would have had to be hammering the f**k out of it to melt a piston with a lean out. If you were running the engine in, then I would have to ask...why?
Its a pure smoke machine that has a nice knock on start up, its well and truly FUBAR, I wish it was just a fouled plug!!! I wasn't giving the car a hard time and never hit boost in it the handful of times i've driven it as it wasn't tuned 100%. It had a pretty aggressive tune on it so im told and wouldn't of taken much to do the damage that it has done.
It was a stock RB20 that i dropped cams, cam gears, injectors etc into with a base tune to get the car running again for rego.
Either way the engine is gone and it leaves me with a car i can't drive/sell the way it is again and this is the second time so im a little over cars at the moment!!!
kriss on NS.com i think it was had an rb20det for 500bux. in melbourne.
i know someone with an RB24 for 2.5k then sell your cams and you are down to around the 2k mark. or you could have a fresh stocker for the 3k mark as you said.
Try EKW in Melbourne. Been in business a long time, and my engine off them is perfect after 4 years of use/abuse.
They dont buy locally, they only wreck std cars in Japan which have been compression tested off the starter motor and had the sumps removed for inspection. The motor cost me $600 and i swapped over manifolds and pumps etc off my old motor as they were a known qty.
They come with start up warranty, and i think its well worth a phone call. Tell them you dont want the loom, turbo, manifolds, CAS etc.
Real sorry to read about the dead motor :D
I'll have a look and see if i can find it.
Real sorry to read about the dead motor :blink:
EKW have none and haven't for a while but thanks for the heads up mate.
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
