  • Replies 108
little update
turbo will be backon wednesday
im thinking of getting a blowjob vavle along with the new turbo
wats the though on that?
Stock BOV will be fine... unless you want that ghey "PSSSHHHHHTTTT" when you lift off.
nice blitz filter, looks exactly like mine lol
whats interesting about it?? i ask because i cant have volume on my machine, people will hear
I think Danny is pointing to the "tu tu tu tu".
Different to "psssshhhhhtttt", but still ghey...
... Why would you want your M35 to sound like a crappy VN Crappydore?
go watch some of the edward lees videos. the old man (edward) has no idea about cars, it makes me wonder how he sold cars! he was driving mine (thats where it came from) and i was explaining things to him! according to him (and he says it on the video) they have a VQ35 motor, and dual zone climate control! wow i had no idea hahah not to mention tv and sat nav!
nope, its air bouncing back from the throttle and going back out the turbo. its essentially air changing direction!
the other flutter you hear on WRC cars are a pop off valve (i think) not to be confused with a blow off valve. i think they go after the throttle body not before it like a BOV does
so how do i get that damn fluttering sound
there is a VERY cheap way to do this.
find the BOV return pipe where it goes back into the intake. remove pipe. insert a coke bottle lid (i found pepsi and fanta were better for performance) and put a clamp over it so it doesnt move. replace pipe. flutter will now occur.
if a coke bottle lid isnt big enough, just put something in there that wont leak or move. but remember to clamp it! you dont want it being sucked into the engine.
An even cheaper way (have you seen the price of coke?) would be to disconnect the vacuum line from the BOV itself. Buy I do not really recommend it - The factory didn't put them in for the sake of it, the pressure reversion isn't healthy for the turbos wellbeing.
that wont work. the spring tension itself without the vacuum line behind it isnt enough to keep it shut all the time. it will open with the boost pressure and also with the sudden pressure increase when the throttle closes
:ninja: You really want to waste money on pssssshhhh or tu tu tu tu!!!!....couple more dollars and you can go paddle shift.
....or even different headlights aye Cam :)!!!
So what do you want? Paddles or a manual??
nyaanyaa all you want bud. Once the front is done, all I will feel is satisfaction when I look at my car... I also take solice in the fact that when you look at your car, all you see is a stoned Pokemon. :ninja:
Edited by iamhe77
Fair call - I didn't know if the spring would hold it closed or not.
But the point about keeping one in use remains!
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
