http://www.bom.gov.au/cgi-bin/wrap_fwo.pl?IDY68029.txt
IDY68029
Australian Government Bureau of Meteorology
MEDIA:
NO USE OF STANDARD EMERGENCY WARNING SIGNAL [sEWS]
TOP PRIORITY FOR IMMEDIATE AND FREQUENT BROADCAST
TSUNAMI WARNING NUMBER 1 FOR PARTS OF VICTORIA
Issued by the Joint Australian Tsunami Warning Centre [JATWC] at
8.28pm 15 June 2009
TSUNAMI THREAT TO THE MARINE ENVIRONMENT
SUMMARY:
Tsunami warning for the marine environment for parts of VICTORIA.
Threatened areas extend from Lakes Entrance to Gabo Island including Gabo
Island, Lakes Entrance, Mallacoota and Point Hicks.
Possibility of DANGEROUS WAVES, STRONG OCEAN CURRENTS AND SOME LOCALISED
OVERFLOW ONTO THE IMMEDIATE FORESHORE for several hours from 10:15 pm [EST]
Wednesday.
Although major evacuations are not required, people are advised to get out of
the water and move away from the immediate water's edge.
Next update will be issued by #next_issue_state#.
For latest and further information call 1300 TSUNAMI [1300 878 6264] or visit
www.bom.gov.au
DETAILS:
A threat of DANGEROUS WAVES, STRONG OCEAN CURRENTS AND THE POSSIBILITY OF SOME
LOCALISED OVERFLOW ONTO THE IMMEDIATE FORESHORE exists for parts of
VICTORIA from Lakes Entrance to Gabo Island including Gabo Island, Lakes
Tsunami effects are expected at the following locations from these times:
Lakes Entrance after 10:15 pm [EST] Wednesday
COMMUNITY RESPONSE ADVICE FROM THE VICTORIAN STATE EMERGENCY SERVICE
- While major evacuations in these areas are not required, people are advised
to get out of the water and move away from the immediate water's edge of
harbours, coastal estuaries, rock platforms and beaches.
- Boats in harbours, estuaries or shallow coastal water should return to
shore. Secure your boat and move away from the waterfront.
- Vessels already at sea should stay offshore in deep water until further
advised.
- Do not go to the coast to watch the tsunami, as there is the possibility of
dangerous, localised flooding of the immediate foreshore.
- Check that your neighbours have received this advice.
CAUTION:
Tsunami waves are more powerful than the same size beach waves, with the first
wave not necessarily being the largest.
Low-level effects may be observed in neighbouring coastal areas. People are
advised to take care.
TSUNAMI SOURCE:
An undersea earthquake of magnitude 7.9 [Latitude 45.960S Longitude 166.470E ]
occurred at 07:22 PM EST on Wednesday 15 July 2009 near OFF W. COAST OF S.
ISLAND, N.Z..
Sea level observations have confirmed a tsunami.
The earthquake of magnitude 7.9 [Latitude 45.960S Longitude 166.470E ]
occurred at 07:22 PM EST on Wednesday 15 July 2009.
The NEXT UPDATE will be issued by #next_issue_state# local time.
FOR LATEST AND FURTHER INFORMATION:
Call 1300 TSUNAMI [1300 878 6264] or visit www.bom.gov.au
FOR EMERGENCY ASSISTANCE:
Call the VICTORIAN STATE EMERGENCY SERVICE on 132 500
EST = Eastern Standard Time
CST = Central Standard Time = EST - 30 minutes
WST = Western Standard Time = EST - 2 hours
The JATWC is operated by the Australian Bureau of Meteorology and Geoscience
Australia
https://www.sau.com.au/forums/topic/279280-tsunami-warning/
It was over 2 hours after it happend.
Even if it did happen they were only estimating it to be like a 20cm wave.... OOOOOOOOOOOOOOO lol
shame i was quite hoping for some excitement... but also living in the hills it wouldnt have made much of a diff
https://www.sau.com.au/forums/topic/279280-tsunami-warning/#findComment-4717108
*waits for some asehole to make a boat joke about 33s*...
Quick, everyone get in my R33.
After the floods die down we can go for a cruise...to the Caribbean...
:mellow:
For the record, I do take warnings very seriously...at first. But not unnecessarily-updated-every-ad-break-minor-shift-in-some-subcontinent's-plate crap. After reading this full warning issue I'm surprised it got as much attention as it did. Fair enough to warn the mariners and islanders. But the word tsunami is now synonymous with thousands of people dying (despite the fact these small ones are quite common), so the newsmedia tend to jump on that one.
Edited by Birds
https://www.sau.com.au/forums/topic/279280-tsunami-warning/#findComment-4717679
remember not so long ago the bush fire's ? everyone cracked it cause there was enough warning.
now there is warning, may be over the top, but people were alerted, saves there own arse's and gives residents a bit of heads up, they cant get the weather right nor can they tell the size of a wave coming from 2hours away.
there will always be someone out there who will jump up and go ' there was no warning, we could of been killed, whats the government doing about it?'
even if there was no threat, then sure enough everyone jumps on the band wagon.
https://www.sau.com.au/forums/topic/279280-tsunami-warning/#findComment-4718459
Yer I agree warnings are a good idea, it's just that in this case the severity was a bit on the low and I feel the media/BOM were jumping the guns on a slow day.
On the side, does anyone know if this tsunami had much of an impact on anything? Docks, ships etc?
https://www.sau.com.au/forums/topic/279280-tsunami-warning/#findComment-4719894
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
