well the ecu cut in my 33 was savage. like someone had jammed their foot on the brake for a second and then it kicked back in. that was at 15psi (about 1 bar). if you got to 1.3 bar then it's pretty safe to say that you don't have it
When you drive it that is..............
Yet to see her Bubba!
She was a daily driven 30 for nearly 2 years! Soon enough though mate, pulling the engine out tonight and putting it on the stand to strip it down and send to the machinist next week :iluvff:
Definitely miss her though, the laggy stag just doesn't quite cut the mustard :D
Edited by bubba
your AFM has a frequency range that it can measure.
it measures air flow.
14 psi = x amount of air flow.
17psi = y amount of air flow etc etc
once the amount of air going through is higher than the afm's limit, the ecu gets the message that it is getting too much air and the ecu adds more fuel..
so you get that misfire as it runs rich.
solution?
re-map of your ECU and an Z32 AFM.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
