hi guys just like to ask what my prob may be
when your in 1st and you take off from a set of ligths and nail it.. it gets to rev limiter and bounceses on it 1-2 times then flat lines (cuts out) until you go 2nd
what would cause this prob??
Nat
Edited by mr-r33
https://www.sau.com.au/forums/topic/279612-r33-flat-lines-once-it-hits-limiter/
  • Replies 44
Posted Images
:down: You must be joking...
all am trying to do is work out what is up with my car and what i put in the first post was the best way to describ it
so pls if you can't help dont post
and if every one wants to act like a 12yr old here you go
PS like no one on this forum has never hit limiter in there car....just to add i dont do it on the streets as i dont drive the car. my misses dose...i only drive it on the track
oh oh befor i for get i know i cant sell so no point telling me something that i all ready now.
Of course it flat lines - it's hit a limit. It's doing exactly what Nissan designed it to do. It protects the engine from idiots.
Actually Daniel, the problem is somewhere between the left ear and the right ear - I think it's called a vacuum.
do you know what flat line means?...what i'am saying is it gets to limiter then it's like you turn the key off and restart it once in 2nd
thanks i know i have a vacum between the ears it absorbes all the info better then rocks
Edited by mr-r33
Is that so?
You're the one acting like a 12 year old. You're driving like you're playing a computer game? Learn how to drag race properly. Both power and torque curves stop way before the rev limiter - there is simply no need to take the engine RPM that high.
sorry ppl for wasting my time here i guess the question is just to hard for a lady to answer ill go to a forum where they no about jap cars not a forum where they think they no about jap cars
Go to another forum...but before you do, perhaps consider that given everyone here is telling you how much of a jackass you are...you might be wrong in what you are doing and saying? We're not the ones who are going to end up with a conrod through our engine blocks. And I'll warn you...you will get the same responses from any knowledgeable forum. What really made me laugh is you saying "Jap cars" as if this is a Jap car specific "problem"? Go back to playing Need For Speed you idiot.
Edited by Birds
Is that so?
yes that is so not that long a go i went to oran park skid pan for the first and this is when i notice the the prob
not to be smart but i dont play computer games or game consoles....i dont drag race and the only time i have ever hit the limiter was at the skidpan when i spun out (i'm not saying i know how to drive)...and the car has only been rego for 2weeks or there abouts and the misses drive it as i'm on my green P's and have my 2 kids in the car most of the time so to do any thing of they above with kids in the car or evern with out kids in the car your an idiot
hey man i'm just trying to work out what is up with it
Why is the problem bothering you if the only time you hit the rev limiter is at a skidpan?
I can do anything in my car without hitting the engine rev limiter...even burnouts...but they aren't really my thing. Shift long before the limiter and practice throttle control...then you will be fine. I'm guessing your ECU shut down your engine, as is the function of a rev limiter, to protect it. Much the same thing happens when you hit 180km/h in a JDM vehicle.
hmmm ok thank you....i was chating to a mate a few days a go and he thinks it may be the CAS as the car was in a aco by the previous owner.
Well a quick fix for this problem, Firstly BEFORE you get to the redline you need to rapidly remove your right foot/shoe from the accelerator pedal. Then with your left foot/shoe you need to press in the pedal furthest to the left ( this is called the clutch pedal ) Whilst that pedal is depressed , With your left hand you need to reach over and grab the gear stick and gently but assertively select the next gear. When this sequence is complete gently but assertively release pressure from the clutch pedal ( your left foot/shoe ) until pedal has completed all of its travel. Resume acceleration by pressing the pedal furthest to the right ( Accelerator pedal )
Hope that helps your problem :)
cheers man now i see what i was doing wrong...i was flat changing and for getting about lifting the right foot/shoe befor changing gears :):ninja:
i understand wat ur saying with the (flat line) bit if its a factory computer i cant say from experience cuz ive never had a standard computer but dont they have sum sorta protection cut that basically stops the engine from revving completely..... my mates lil sss pulsar in lil fits of rage hes just hold it on the rev limiter and it would just die in the arse or as old mate says it flat lines as if the fuel or ignition had been shut off for a second.... not saying its the same thing but i defo noticed it.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
