Ok so a mate suggested to me the other day that since I am running standard injectors and fuel reg, that until I can afford to get a remap/Nistune RB20 tune done, that I should take out my Microtech LT10S (the usual overfueling, shit fuel economy, horrible cold starts, fouling plugs, the fact that WOT = smokescreen deployed, and a EPA warning letter on top of that!) and replace with a standard RB25 ECU (think its all wired up still into the R32 loom).
Now assuming that wiring is all okay, am I likely to run into any major issues from running FMIC, KKR 480 turbo (boost set to actuator pressure of 8 psi) and turbo back exhaust? The motor is a Series 1 Stagea motor, would I be any better off with the Stagea ECU or just a normal R33 Series 1 do?
I do have an airflow meter sitting in the intake pipe albeit disconnected, and the O2 & VCT are disconnected.
https://www.sau.com.au/forums/topic/280128-microtech-removal-questions/
hard to say, but personally I would think the only way you'll know for sure is try it. half of us will say it wont work, and the other half will say it will at the end of the day there is a sure fire way of knowing.....
So do you intend on connecting them? AFM you won't get away with, the other 2 yes, but it's going to run like shit without VCT and o2.
If you can sort out the wiring, then provided you stick to 8psi then I can't see a reason why it wouldn't work.
nah I will connect everything up, there are around 69000 R33's around here so I'm sure I'd be able to get a lend of one, its more fingers crossed that the loom hasn't been butchered, but I'm assuming that there's no major differences in fuel maps etc for Stagea vs R33?
Hopefully the ATTESSA *might* run with a stock ECU as well, but I'm not holding my breath.
Yeah it's mainly come about because I'm so sick and tired of the way the Microtech behaves, but then when you're travelling 400+km to get a decent tuner it's not a cheap exercise at all.
  • 1 month later...
spose ill do a bit of an update; finally got a stock computer, threw it in, hooked up AFM... and nothing! I'd forgotten that the Microtech had a relay set up in the boot for the fuel pump so stock computer wouldn't prime! I'll be getting a mate to rewire it for me in the near future, then we'll see what happens...
the stagea ecu is remappable with a type 4 nistune board andif tuned right passes all the epa tests.
nah gonna sell it to some sucker with a dirty 30 or a rotary owner :)
URAS: I thought that the type 4 board was only compatable with the NEO ECU? That's how I read the Nistune website anyway. Mine is a Series 1 Stagea motor with the old school RB25 and ignitor module.
ah yep ser1 needs the z32 ecu trick, sorry should have read your post better sorry.
will likely not bother with Z32 and just go RB20 remap and ditch the VCT since I already have a stock RB20 ECU lying around.
best running a jaycar switch then, ive got some dyno tests i did here with and without the vct and the hole in the mid range is about 15-19rwkw deep....
  • 6 months later...
might bump this up again since I'm once again looking at this, I have no idea if the standard plug is for the R32 or R33 ECU, will this matter? when I plugged in the R33 ECU the fuel pump refused to prime, however there is a relay type thing for it in the wiring in the boot, would i need to circumvent that?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
